Author Topic: Turns over but won't fire? HELP!!  (Read 3872 times)
Malachi
  • Crawley, West Sussex
Re: Turns over but won't fire? HELP!!
« Reply #15 on: 28 May 2008, 22:43:39 »
It is a T reg, where would I get this sensor from?
rickyboy
  • Glasgow
« Reply #16 on: 28 May 2008, 22:46:27 »
Always replace with genuine vauxhall sensors.  Cheap ones off ebay etc usually turn out to be a false economy.  Does sound like the crankshaft sensor is needing replaced but does usually flag a 19.
Malachi
« Reply #17 on: 28 May 2008, 22:49:34 »
Ah ok, so if I go to my vauxhall dealer they should sell me one?
Also I've seen the walkthrough, finding the sensor next to the oil filter doesn't seem a problem but it is also connected at the back of the engine, does anyone have a pic of this or is it simple enough to follow the lead back?
« Reply #18 on: 28 May 2008, 22:54:48 »
Its easy to find .. clipped to the engine lifting bracket, next to the injector multi-plug ... follow the injector wires back .... :)
When I did mine I took the scuttle off for easy access.. as I have big hands.. ..
Malachi
« Reply #19 on: 29 May 2008, 18:53:54 »
Don't know if this adds anything but when the car was rolled and tried to start it made a sound as if it was firing but just not getting there.......
rickyboy
  • Glasgow
« Reply #20 on: 29 May 2008, 19:16:21 »
Have you checked the basics?  I had a little trouble starting the car recently due to the airbox not being clipped on properly. Check the state of the air filter and also check the injector wiring is all intact.  I assume there are no holes or blockages in the exhaust either.
« Last Edit: 29 May 2008, 19:17:02 by rickyboy »
johnnycboy
  • Colchester
« Reply #21 on: 29 May 2008, 19:20:57 »
I had problems with engine cutting out, and turned out to be crank sensor, annoying thing was did not have any codes or eml, took the advice of here here and hey presto the beast is now flying, albeit on two wheels most of the time :y
Heres your picture http://www.omegaowners.com/forum/YaBB.pl?num=1174321688
« Last Edit: 29 May 2008, 19:23:11 by johnnycboy »
Malachi
« Reply #22 on: 04 June 2008, 20:38:36 »
Hey, did turn out to be the sensor after all, many thanks for all your help!
johnnycboy
  • Colchester
« Reply #23 on: 04 June 2008, 20:53:21 »
glad you sorted it :y
