Author Topic: Turns over but won't fire? HELP!!  (Read 4292 times)
Malachi
  • Crawley, West Sussex
« on: 28 May 2008, 11:48:46 »
Hoping to god someone can help me as I'm at my wits end. Just got another Omega (2.5 V6 CD T reg manual) and 3 weeks after it won't start  >:(
Went out this morning, the engine turns over, there seems to be power ok but the damn thing won't fire. Was fine yesterday and nothings happended recently to suggest something like this was going to happen. The only thing that had happened is that we had very heavy rain over the past couple of days.
I would really appreciate any help  :-[
Re: Turns over but won't fire? HELP!!
« Reply #1 on: 28 May 2008, 11:50:23 »
Do the paperclip test and see if there are any codes stored:y
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Probably got a code 19
« Last Edit: 28 May 2008, 11:51:14 by Elite_Pete »
Malachi
« Reply #2 on: 28 May 2008, 11:58:52 »
Ok, will do that, and what would I have to do it it is a code 19?
« Reply #3 on: 28 May 2008, 12:00:33 »
If it is 19 then the crank sensor is furbered, but do the paperclip test first, im only guessing ;)
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #4 on: 28 May 2008, 13:41:30 »
The crank sensor is a common cause of this problem with Omega's.
Malachi
« Reply #5 on: 28 May 2008, 13:43:27 »
*If* the crank sensor needs replacing is it expensive and could I do it myself being a novice?
jasonxr2racer
  • North West
« Reply #6 on: 28 May 2008, 13:53:45 »
Sounds like same prob as i'm having but i got a code 74.
Try removing pipes leading to inlet plenum and see if it starts.
Mine does doing that.
Going to try another MAF sensor when it arrives.
« Reply #7 on: 28 May 2008, 13:54:03 »
There are two different sensors and it depends on the shape of the plug and its easy to do :y
« Reply #8 on: 28 May 2008, 14:35:07 »
It's dead easy, there is a guide on here.
Flash the codes, first...
Malachi
« Reply #9 on: 28 May 2008, 18:50:08 »
OK, just followed the instructions but just got a 12 then 31, did it three times to check and same again.
So is this a good thing or bad thing?
« Reply #10 on: 28 May 2008, 20:32:38 »
I would expect a code 19...
Is fuel getting through - fuse 18 ok?
Malachi
« Reply #11 on: 28 May 2008, 20:54:36 »
Just checked, yep fuse 18 for the fuel pump is ok.
rickyboy
  • Glasgow
« Reply #12 on: 28 May 2008, 22:33:09 »
Code 31 is crankshaft sensor (no signal) opposed to code 19 - crankshaft sensor (incorrect signal).
Malachi
« Reply #13 on: 28 May 2008, 22:40:30 »
It says on the list:
31   No Engine RPM Signal
I thought that was normal if the engine wasn't running?
JasonH
« Reply #14 on: 28 May 2008, 22:42:43 »
A 12 and 31 are normal if the engine isn't running.
Later cars do not show the tell-tale 19 code.
If the car turns over fine but with no sign of a spark the prime suspect is the crank sensor.
Cost about £50 for the sensor. Fitting 30 mins if you know what you're doing. Otherwise you'll spend a fair while locating the sensor and connector.
