Author Topic: Replacing Glovebox latch  (Read 1451 times)
« on: 05 June 2008, 20:20:14 »
Need to replace the latch on the glovebox, it is in 2 pieces.
Bought a nice shiny new one, only £6 from Vauxhall  :y
Bit of brute force and screwdriver jiggling got the last 1/2 out the glovebox, swapped the barrel over, spilling a few pins  >:(
New latch working fine, now how to install it in the car?
There are cutouts where it looks like it should slot, but I can't get the bugger in  >:(
Managed to break the new latch trying to install, ok maybe punching it in wasn't the best idea ever  >:( >:( >:( >:( >:(
Is there a technique I am missing, be a few days before the next new one arrives  ;D
Re: Replacing Glovebox latch
« Reply #1 on: 05 June 2008, 20:28:06 »
i think the airbag needs to come out  :(
« Reply #2 on: 06 June 2008, 10:36:10 »
Cheers Tunnie, anyone else got any pearls of wisdom?
Robin Hood
  • Nottingham
« Reply #3 on: 06 June 2008, 11:02:36 »
Repaired my glove box latch a few months back but can not remember any problems in reassembly, having already found the fifth screw.
Is fitting the latch to the door or the box into the fascia, the problem?
« Reply #4 on: 06 June 2008, 11:06:00 »
latch into the door.
Not used any screws, looks like it should clip in with proper application of force / leverage  ;D
Maybe not a quick dirty fix after all :(
Robin Hood
  • Nottingham
« Reply #5 on: 06 June 2008, 11:17:47 »
Have you tried holding in the locking tabs to the sides of the door when fitting the latch?
It might be easier to fit the latch with the doors inner liner removed.  Unfortunately I think this means removing the whole box first in order to remove the door and then it’s liner - hence the 5 screws.
« Reply #6 on: 06 June 2008, 11:23:10 »
thats roughly what i was trying, ill have another little go with the new one, if i cant wiggle it in its glovebox out time  >:(
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #7 on: 06 June 2008, 11:26:17 »
Jimbob did mine around a year ago, I managed to get mine in without taking any panels or airbag off.
I got a long thin flat screwdriver, pushed the handle in one side so the tab went behind the cut out, then comes the difficult part (as you know) slide the thin screwdriver down the side and push the tab gently so it flips behind the cut out, a pain in the arse but treat it gentle like you would a women ;) ;D
« Reply #8 on: 06 June 2008, 12:30:19 »
Cheers, thats the sort of thing I was trying before using excessive force to seat it fully home  :-[
« Reply #9 on: 06 June 2008, 12:44:58 »
Let us know how it goes, mines always been broken, never bothered to fix it yet.
« Reply #10 on: 06 June 2008, 12:48:44 »
I have taken photos as I went, with the intention of a how 2....
right up till i breaked it up  ;D
fyi - black latch 9105030, £6+ retail  :y
still intending doing it though  ;D
« Reply #11 on: 06 June 2008, 12:49:32 »
my first top tip will be have a key in the lock when removing the old barrel, this will stop you spilling levers and springs all over the shop  ;D
Martin_1962
« Reply #12 on: 06 June 2008, 14:36:13 »
Remove the glovebox and dismantle the lid
« Last Edit: 06 June 2008, 14:36:38 by Martin_1962 »
