Author Topic: automatic transmission fault codes  (Read 2403 times)
the nutter
  • bedfordshire
« on: 11 June 2008, 16:29:46 »
hi can anymore can help me ,  i have just done a engine change on a R reg 2.5 v6 petrol elite estate it drives ok using 1 2 3 but when in drive it goes into limb home mode  and it has come up with a fault code  p 1740 touque controll circuit low imput and i have put it on a computer to find out what the fault was but wont clear the fault any ideas on what this means and how to sort
« Last Edit: 11 June 2008, 21:55:27 by tonyb74 »
Re: automatic transmission fault codes
« Reply #1 on: 11 June 2008, 16:31:44 »
whats the millage on your 2.5TD?
The standard fit autoboxes (AR25) don't last much past 120k
Needs the stonger AR35 box fitted which was on 3.0/3.2 Omegas.
mkaminski100
  • Basingstoke
« Reply #2 on: 11 June 2008, 16:35:58 »
It's not the box, it's the engine - don't you have any problems with power?
Friend of mine had same code and we started looking for engine fault - we found that sparkplugs were covered in oil (2.0 petrol). New rocker cover seal fixed the gearbox problem!! :) You may have different problem with your engine power, but I dont know anything about Diesels and cant really help.
There isnt't enought torque (power) from the engine and you get the code. No engine codes?
« Last Edit: 11 June 2008, 16:37:56 by mkaminski100 »
« Reply #3 on: 11 June 2008, 18:48:01 »
Get engine codes read (some TDs are paperclippable)
« Reply #4 on: 11 June 2008, 18:49:43 »
Wrong car!?? - i have just done a engine change on a R reg 2.5 v6 petrol elite estate it drives ok using 1 2 3 but when in drive it goes into limb home mode  and it has come up with a fault code  p 1740
« Last Edit: 11 June 2008, 18:50:47 by dbug »
« Reply #5 on: 11 June 2008, 19:02:08 »
td ar25 issue is mechanical anyway...
mkaminski100
  • Basingstoke
« Reply #6 on: 12 June 2008, 08:07:28 »
I just looked at your details and there’s still “TD”. Anyway – check your spakrplugs.
« Reply #7 on: 12 June 2008, 15:48:02 »
Eh? Sparkplugs? They wouldn't cause the engine ECU to put the gearbox in limp  :-/
mkaminski100
  • Basingstoke
« Reply #8 on: 12 June 2008, 16:04:53 »
Well, he can start from the gearbox. All I am saying is that I had a friend with same fault code and after cleaning sparks from oil, problems disappeared. Oil caused ignition problems and TC didn’t have enough “power” – pump wasn’t creating proper pressure and there was a slippage on the “clutch”.
touque controll circuit low imput – sond like low input, so might be a pump, but might be engine.
Second thought is TC itself. You said that the engine was swapped – did you changed TC as well? AS far as I  remember TD have different from V6. This also might be a cause!!BTW – Yesterday I have unplugged MAF sensor on running  2.2 and had an “Automatic Gearbox” few seconds after !! I will try to do it again today.
« Last Edit: 12 June 2008, 16:34:21 by mkaminski100 »
« Reply #9 on: 12 June 2008, 16:23:14 »
When you did the engine change, did you swap just the block or the entire loom.....was the donor from a manual?
the nutter
  • bedfordshire
« Reply #10 on: 18 June 2008, 19:23:35 »
the engine change i done was a petrol 2.5 v6 elite and not my td as thats running sweet , i got the 2.5 v6 as a non runner as it had dropped a piston and the cheaper option was change engine and it runs fine untill u put in drive then it locks itself in snow mode and sports mode is not working either any ideas  i put it on computer and the only code it come up with was toque converter low imput and it wont remove it from stored fault codes
« Reply #11 on: 19 June 2008, 19:32:38 »
Was donor engine from auto or manual, and was it just engine, or loom as well?
