Author Topic: Elite Washer Bottle  (Read 3611 times)
Elite Washer Bottle
« on: 18 June 2008, 21:33:26 »
MOT today, wipers and washers fine.
Goes to my mates afterwards and no water.   Had a think back knowing the bottle and all fluids had been checked, but was surprised as I hadnt used the washers much.
Topped up, took 0.5 litre of water, washer now working fine.
Why only .5 litre from not working to working.
Any idea's, am going to check it out tomorrow as I remember a mention regards water filter/pickup.
TIA.   :y
Re: Elite Washer Bottle
« Reply #1 on: 19 June 2008, 00:46:06 »
my 99 cdx used to do that, nevr found out why, thought it was as if the fluid had run back down the pipes to the bottle and took ages to pump back up to the nozzle again. used to pump air then come back again after dash warning as well, as if to make you think it had run out and need to fill it again but there was always a bit more in there. :-/
« Reply #2 on: 19 June 2008, 00:49:06 »
ps clean the filter gromit??? :-?
« Reply #3 on: 19 June 2008, 00:54:42 »
 :y :y
robbo299
  • luton, beds
« Reply #4 on: 19 June 2008, 00:55:17 »
I had the dash warning up on my elite some time ago and kept filling it up every week. Turned out that the previous owner may have taken out the pumps to clean filters and didn't put it back properly and it had a slow leak. As it was over the winter months i didn't notice it as the roads were mainly wet most of the time. When i did notice the leak i took out both pumps, one for screens and the other for headlights, and cleaned filters and replaced properly. no probs since then. Only a 10 min job to do both. :y
« Reply #5 on: 19 June 2008, 01:07:32 »
Cheers matey, will check it out tomorrow.   :y :y
JasonH
« Reply #6 on: 19 June 2008, 07:10:52 »
Intermittent washer operation is usually lumps of gung block the pump filter.
2 mins to sort, but plug the hole with your finger whilst doing it or you'll lose all your washer fluid.
« Reply #7 on: 19 June 2008, 07:44:26 »
I might forget that bit, as it will be my mate doing it.  lol    ;D ;D :y :y
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #8 on: 19 June 2008, 08:35:39 »
how do you clean the filters? i've got the bottle out at the moment due to accident so might as well spruce it up while it's in bits :y
« Reply #9 on: 19 June 2008, 08:42:04 »
Mine just seems to go stagnant and smelly really quickly!  :o :o
« Reply #10 on: 19 June 2008, 08:44:22 »
Do you use screen wash or just plain water?  I would be tempted to pop the pump out and flush it 2 or or 3 times and then refit the pump and fill it back up and see if it makes a difference.
« Last Edit: 19 June 2008, 08:46:30 by skruntie »
« Reply #11 on: 19 June 2008, 08:53:23 »
Tried doing this and still goes smelly quite quickly! I might try a stronger concentration of screenwash, although I already have it quite strong!
I can only assume it's because of the location of the bottle meaning it gets warmed a little by the rad? :-/ :-/
« Reply #12 on: 19 June 2008, 08:59:54 »
Not got a dead animal stuffed in there have you?
Never noticed stagnant / smelly washer bottles  :-?
« Reply #13 on: 19 June 2008, 09:10:46 »
Easier with a face lift car though as the bottle is in full view when you have the bonnet open.  ;) Lesser mortals have a grille to remove to gain access!  ;D  :y
A Bic pen also seals the grommet nicely if it's just the pump you're removing.
« Last Edit: 19 June 2008, 09:12:26 by Andy_B »
« Reply #14 on: 19 June 2008, 10:00:10 »
The thought had crossed my mind! But no... Perhaps it'll sort itself out if I used them more! I might not treat the screen with rainex for a while and see if I get an improvement when I need to use the washers more! :-?
