Author Topic: HBV Replaced but...  (Read 1739 times)
HBV Replaced but...
« on: 20 June 2008, 14:39:05 »
... unfortunately I managed to crack the windscreen in the process!!
It wasn't too bad a job to do TBH. Took me just under 2 hours, over an hour of which was trying to get the bl00dy wiper arms off!!!! My screen had a few chips and a small crack which I only noticed when I started but this has grown considerably now from my leaning on the screen when trying to pull wiper arms off! Never mind... I was going to get a new one anyway when I noticed the crack!!!
A small tip for anyone else who needs to do this simple job... When trying to get the arms off I soaked the spigot in WD40 (because it was to hand) for quite a while and then found that a gentle tap with a soft hammer on the hinge of the arm freed them off nicely! This after lots of cursing and swearing at all the other attempts!!  ::) ::) ::)
However, once the arms were off I think it took me just over 15 minutes to swap the unit over and then it was just a case of reassembly, topping up the coolant and bleeding/running it up to temperature to check for leaks!  :y :y :y
All in all not a bad job to do... Oh, and I didn't even cut myself, just one small scratch!! TBH I wouldn't have even got that if I didn't have such large hands!!  ;D ;D ;D ;D
Re: HBV Replaced but...
« Reply #1 on: 20 June 2008, 14:43:50 »
Well Done, sounds like not too bad a job for you, and off to autoglass for a new screen!
I would be tempted to chuck new wipers on just before it goes so as not to risk scratching a new screen with old wiper blades  :y
I find a push / pull movement on the wiper arm soon frees em, bit of grease before reassembly should make it easier for next time  :y
« Last Edit: 20 June 2008, 14:44:31 by jimbob »
ians
  • Reading
« Reply #2 on: 20 June 2008, 14:50:10 »
I had the same problem - one of the wipers just would not come off.  I bought the heavy duty Sealey puller in the end which popped it off in a second.
« Reply #3 on: 20 June 2008, 14:52:28 »
Unfortunately I have to use RAC Autoglass people for my insurance... Not overly impressed about it TBH but never mind! I'll just make sure I watch him like a hawk!!  :y :y :y
The wiper blades are only 6 weeks old, 2 months at the most so I'm not too worried about them!
Job was actually easier than I was expecting! Next job... LPG kit I feel!
« Reply #4 on: 20 June 2008, 14:53:27 »
I couldn't get my puller to fit!!! That caused a fair bit of swearing I can assure you!  ;D ;D ;D
jonathanh
  • coventry
« Reply #5 on: 20 June 2008, 15:18:02 »
can you live with the crack until you re-insure it.  TBH I would totally avoid RAC autowindcreens
ians
  • Reading
« Reply #6 on: 20 June 2008, 15:18:22 »
swear box full to the brim then... I told you ;)
« Reply #7 on: 20 June 2008, 15:25:52 »
Errm... No. Not really. Firstly, it's a bit big and secondly, the windscreen provides a large proportion of the structural strength in a car and I like to know it's in good nick should I ever need that strength!!
I've not had any problems, personally, with them when they replace windscreens. It's just any other glass they seem to balls up. Mind you, I know at least one of the local fitters so I know he'll do a good job!
« Reply #8 on: 20 June 2008, 15:26:49 »
Another OOF member has some pretty horrendous stories regarding RAC Windshields ... just hope you have more joy than he did ....
Good luck is all I can say ... :y :y :y
« Reply #9 on: 20 June 2008, 15:29:03 »
I know... But I'm willing to give them a chance. Like I said, I've only ever had good experiences when they replace windscreens... It's just any other glass I've known them balls up!!
« Reply #10 on: 20 June 2008, 15:42:32 »
I wont pass comment but, I am now going to be looking for some new interior trim pieces to try to rectify the work I have had done so far.
Ow yes, 4 different fitters have worked on my car.....so the standard is not to high!
« Reply #11 on: 20 June 2008, 17:33:24 »
Please don't say things like that!!!! They'll be getting it right because I'm planning to stand and watch them!!!
It's not ideal but as the excess is only £75 instead of £Mega for a new one I'll have to chance it!! Like I say, I know one of the fitters and have asked him to make sure he does it if he can... I just hope all goes well!!!
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
« Reply #12 on: 20 June 2008, 17:37:57 »
Can you not get it done by a company of choice and then bill the insurance? My policy allows this. Worth checking  ;)
« Reply #13 on: 20 June 2008, 17:43:39 »
Unfortunately the small print says that they will only pay a maximum of... Can't remember but it'll probably take them ages to find it and I haven't the patience to call Mumbai and find out!!!
psychnurse
« Reply #14 on: 20 June 2008, 17:47:17 »
Nevermind mate. Im sure it will be fine if you are watching them and your mate does it. Anyway, surly it will be better than a broken windscreen. Not that I have experience in these matters  ::)
