Author Topic: fault codes?  (Read 1040 times)
spudboy
  • norwich
  • life is like a potato
fault codes?
« on: 22 June 2008, 21:25:54 »
Hi was hoping someone can tell me how to convert the flashes from the eml while doing the paperclip test into a fault code,when i do it i get the light to flash 10,3,3,5,10,3,4,10,3,5,1,10 then it repeats,not sure if i am reading this right or not so any help would be great,from reading through the forums i am guessing its the crank sensor,if so how can i tell what one i need to get for it to be right for the engine,its a r-reg 2.0 cheers
Re: fault codes?
« Reply #1 on: 22 June 2008, 21:36:20 »
0335 - Incorrect RPM Signal
0340 - Camshaft Sensor Incorrect Signal
3510 - Not a recognised code
Sounds like a crank sensor failing to me, any other symptoms?
spudboy
  • norwich
Re: fault codes?
« Reply #2 on: 22 June 2008, 21:54:10 »
Well so far just before the light comes on the revs dip and a couple of times the revs have gone up and down,but if i pull over turn the engine off and restart it it can be fine for the rest of the day or like today can do it quite a bit
Re: fault codes?
« Reply #3 on: 22 June 2008, 22:06:40 »
cam and crank sensors sound like they need doing
spudboy
  • norwich
Re: fault codes?
« Reply #4 on: 22 June 2008, 22:14:26 »
ok thats what i was thinking,been reading through all the old posts and have come across a few posts that sound like mine,anybody know what the part numbers are so i can get the right bits and give it a go at changing them
