Author Topic: water lying under car  (Read 1457 times)
gizmo
  • livingston
« on: 28 June 2008, 12:25:19 »
hi just bought a vauxhall omega 2.6 v6 cd saloon going to london next week to pick it up and bring it back to scotland but there is a problem now my bro has told me that after 3 months of the car sitting doing nothing he got it started and left it running only to discover that there was a pool of water lying under it and this water bottle was empty does anyone know wot to do or what may of caused this thanks
Re: water lying under car
« Reply #1 on: 28 June 2008, 14:35:09 »
a couple of things, and i am not an expert on here, heater by pass valve  (hbv) under the scuttle at the back of the engine. 35 from vox dealer, or more seriously oil cooler cover is leaking search both they are well covered on here. Fill it back up and try to see where it coming from perhaps. Try to look from the top of engine rather than from under the car as the engine sits at an angle and all liquid seems to run down the back of the gear box area so that wont help probably. Maybe check hbv first if thats not leaking then prob Oil cooler, its is right in the middle of the v under a cover beneath the plenum and inlets so you may if you stick a torch in, be able to see water in there, it should be dry in there, also water pump in same area and that can leak as well. Check easiest stuff first like pipes and rad obviously. Hope helps.
jonathanh
  • coventry
« Reply #2 on: 28 June 2008, 18:33:51 »
typical oil cooler failure is oil in the header tank so my money is on the HBV
STMO123
« Reply #3 on: 28 June 2008, 18:38:28 »
Hbv sounds favourite but, if it's been sitting for a good while, check out all the hoses first.
JueV6
  • Kent
« Reply #4 on: 28 June 2008, 18:55:38 »
I think mines the dread pipe from the back of the block :'(
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #5 on: 28 June 2008, 23:00:14 »
Locate the HBV and put some screwed newspaper /kitchen roll around and behind it you can get it in I managed it, then either go for run or just leave engine running then if its wet you know there's a leak back there, if its bone dry start looking elsewhere for water leaks hoses etc
hotel21
  • The Kingdom of Fife
« Reply #6 on: 28 June 2008, 23:39:02 »
In no particular order.....
Skuttle drain is overflowing into the front footwell and leaking out the floor pan onto the ground.
Aircon condensate is dripping onto the ground.
Water/condensate is dripping from a hole in the exhaust centre sections.
Favourite (as you are also loosing coolant) is the heater bypass valve.  See if it still leaks when you change the position of the heater controls.  Normally only leaks when heat is on or off, not both (but not unknown)
If its still water in the header and not liquified caramac then unlikely to be the oil cooler....
Check the water hose clips throughout the system incase one has rusted through (old wire types especially) as you may now have one leaking.....    :y
