Author Topic: 2.6 V6 Fluid Leak  (Read 1508 times)
chubscrew
  • mansfield
2.6 V6 Fluid Leak
« on: 26 June 2008, 19:19:10 »
Hi Everyone,
Just been onto the drive to be greeted by a stream running from under my 2.6 V6, it seems to be dripping off of the bell housing. Checked the fluid and it has a sweet taste, possibly a water leak, anyone any ideas previous problems.
P.S Does the Omega have a hydraulic clutch?
Cheers
Re: 2.6 V6 Fluid Leak
« Reply #1 on: 26 June 2008, 19:33:27 »
Possibly the HBV .. check the water level ??
(unless its persisting down like it is here . in which case it's RAIN !!!!!!   )
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 26 June 2008, 20:06:23 »
First thing to check is the HBV like already said mate :y
« Reply #3 on: 26 June 2008, 20:16:35 »
And yes, Omegas do have a hydrauli clucth with concentric slave cylinder
chubscrew
  • mansfield
« Reply #4 on: 26 June 2008, 20:34:43 »
Checked the fluid and its low, topped up, will i need to change the valve?
« Reply #5 on: 26 June 2008, 21:29:44 »
It would be a good idea to .. and sooner rather than later ... leaks don't mend themselves, they get worse, and eventually will leave you stranded at best ... or with an overheat at worst :(
ALSO ... and this is important to your wallet ... the HBV usually leaks all over the DIS pack ( if you have one of course - not sure if the 2.6 does) which then fails and needs replacing at mega wonga .... :(
chubscrew
  • mansfield
« Reply #6 on: 30 June 2008, 20:58:53 »
Followed Pete G`S How To and changed the HBV, he is right about the swear box, I must have filled it!
    • 530D M Sport, 330i Coupe
« Reply #7 on: 30 June 2008, 21:08:30 »
2.6 / 3.2 have dis cartridges on each bank so don't tend to get drenched by the HBV failing. Still a fun job though!
« Last Edit: 30 June 2008, 21:08:54 by VXL_V6 »
