Author Topic: Sanity check - scuttle drain  (Read 2722 times)
JohnM
  • Newark on Trent
    • 2.5M Estate
« on: 01 July 2008, 20:05:19 »
Unavailable at the weekend to get banned, but able to play miggys anyway I spend a happy Saturday half-doing some jobs.
So I thought I should check that drain.  So having gone about it the long way round (two wipper arms on the floor!); I was, and still am, perplexed.  Where is the Beasty?
I should add it was all quite dry in there other than a tiny bit of damp 'stuff' (removed most) at the very bottom of a rubber bung rearward of a loom heading into the engine bay.  So I'm assuming all is actually well in there.
No photos so a sketch follows.
Whilst I'd expect this to be the same on all, this one is a mini-facelift 2.5 auto with a/conn.  Narrow (white) paper? cabin filter that came out from two clips near the top of the plastic holder/molding.
|                              |                      filter unit                 |
|      bung                 |                                                    |
|                              |    X                                               |
|                              |                                  sm.loom         |
|      loom                 |                                                    |
|------------------------|                    strut top
Mmm, realised I can't really remember the bits here.
Anyway, I expect the bung to have a route out as this looks like it *could* go to the wheel arch behind the strut, but it definately felt really solid.  I couldn't get me hand down there very well so could pull the bug up and out.
So, was I close or need to pay more attention?
- has anyone got a bright photograph of the article.
>corrected for mini-facelift
« Last Edit: 01 July 2008, 21:16:00 by JohnM »
johnnycboy
  • Colchester
Re: Sanity check - scuttle drain
« Reply #1 on: 01 July 2008, 20:19:13 »
thats the bung at the bottom, I used a cable fish rod to push all the crap out then flushed it through.  when cleared water will drain down into engine bay and out.  ;)
rickyboy
  • Glasgow
« Reply #2 on: 01 July 2008, 20:20:17 »
Power washer works a treat!
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #3 on: 01 July 2008, 20:43:36 »
Was yours also looking dry/okay before you did that.
I do wonder if someone has fitted a solid bung in mine - or is it *that* blocked?
Where in the engine bay is it's outlet?
Richard A
  • Aldridge, West Midlands
« Reply #4 on: 01 July 2008, 20:47:37 »
The outlet is at "x" but it then turns towards the N/S/F wheel on a pre-face lift 2.5 with aircon, on later models it drains forward. So look under the F/N/S wheel arch and you should see a rubber flap, lift it open, all sorts of sh!! should come out. :y :y
Good luck
Regards
Richard a
richard a
johnnycboy
  • Colchester
« Reply #5 on: 01 July 2008, 20:51:10 »
mine was partially blocked, water in the bottom, even after i cleared it, it does seem solid but thats ok. look down the passenger side engine bay and u will see a run off at the bottom, thats where the fluid runs out.  hope that helps :)
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #6 on: 01 July 2008, 21:10:18 »
Good luck
Regards
Richard a
Ah, you spotted my "x".  I couldn't believe the drain would be that high.  So it could stand with 3-4 inches of water without draining lower?? (Would explain the 'overflow' problem into the inside).  That will take a smaller rod than I was using.
So to be clear - poke through the smaller bung/stop at about 'x' (which IIRC is about half way up the bulge) - after finding the flap in the wheel arch and getting wet!
« Reply #7 on: 01 July 2008, 21:27:47 »
did 2.0 99 f lift a while back.standing by side of car, the "bung" was at bottom of deepest part of the furthest section, the bung is the drain and has a right angle bend and drained facing to the front of the car, water ran forward( to the rad) along a "trenched" chasis member. i could not just poke through down to the floor as chasis member was in the way.
 Did not go near the under side or the car for lack of a wet suit. :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #8 on: 01 July 2008, 21:39:58 »
Trade club card holder
Code scanner available
bigdods
  • Brackley
« Reply #9 on: 02 July 2008, 13:17:28 »
Do you have to remove the wipers to get to this or is there an access hatch on top of the scuttle ?
« Reply #10 on: 02 July 2008, 13:19:14 »
Access panel is windscreen bottom edge, right corner as you look at the engine bay, peel the thick rubber strip back about 9 inches to make it easier to pop the panel .. it is hinged at the windscreen edge.
HTH
« Last Edit: 02 July 2008, 13:20:52 by entwood »
bruce
  • HEMEL HEMPSTEAD HERTFORDSHIRE
« Reply #11 on: 02 July 2008, 13:59:01 »
I used this guide to clean my drain out, worked a treat.
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
Bruce
Richard A
« Reply #12 on: 02 July 2008, 16:17:37 »
Sorry John, the drain IS at the very bottom, anyway you found the outlet under the F/N/S/wing, face lift models ie after '99 drain in the engine bay.
regards
richard a
richard a
ians
  • Reading
« Reply #13 on: 02 July 2008, 17:48:24 »
The term 'bung ' is misleading - sounds like a bath plug that would stop it draining!  Its actually more of a grommet.
I used a piece of stiff electrical cable (the single core stuff they use for wiring houses, not flex) bent to shape (courtesy of a guide somewhere :y)
Personally I wouldn't recommend blasting it with a  hose - that is more likely to fill the whole scuttle up if its blocked and then you definitely cant see what you are doing.
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #14 on: 02 July 2008, 20:33:45 »
I was doing this the challenging (long) way round!
- Yeah, I got that (afterwards) and it was being a bit of a s*d to get back too.
Bruce
Photos look too dark on my monitor, why I asked if anyone had some bright photos.
Okay, I'm offically confuzzled.  I know the drain should be at the bottom but I don't want to puncture an otherwise good bung.  Everything was quite dry in there so I'll leave it and consult later (and I know the 'secret' way in now anyway).
Are all the cars the same ?
- you know, if the car was out I'd open her up again and take some photos myself!
