Author Topic: headlamp fitments?  (Read 4183 times)
hol666
  • Lechlade, Gloucestershire
Re: headlamp fitments?
« Reply #15 on: 14 July 2008, 19:02:32 »
Ok, thanks for the link but if possible I'd like to use what I have.  :)
on the ballast box, does it matter which pin is the positive because there doesn't seem be any particular way the plug, which I don't have, fits.
that said, would I be better off getting a kit as per above and would that new hid bulb fit in place of the existing one or try and get the headlight loom from a mini-facelift?
Sorry about all the questions but I'd rather it was done well first time.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #16 on: 14 July 2008, 21:51:44 »
pm sent if it helps :y
davlad22
  • Sunny Yorkshire
« Reply #17 on: 15 July 2008, 15:48:32 »
What's different about your kit??? Are you sure it's a H1 fitting???
In theory the power feed from projector lights comes from;
Headlight ---> Into Ballast (on removable plug) --->From Ballast (on fixed plug) --->To bulb.
Hope this helps? It doesn't matter initially which way round the connector is, it just won't work BUT the omega should not require any wiring modifications.
hol666
« Reply #18 on: 15 July 2008, 20:05:57 »
no no, not a kit, Genuine Vauxhall Omega complete headlight units ;)
from a 98 omega, thing is mine is a 95 GLS so pretty sure not wiring  :-[ >:(
they are complete with everything apart from extra wiring, ballast, motors the lot....
replied to the pm HP thankyou ;)
davlad22
  • Sunny Yorkshire
« Reply #19 on: 16 July 2008, 02:26:48 »
It's been mentioned before but you want to get part of the headlight loom/plug from the '98 car to splice into your '95 loom/lights.
MarksDTM is the man for colours/wiring solutions!  :-X
hol666
« Reply #20 on: 16 July 2008, 19:16:05 »
thanks for that, must have missed that bit of info, I'll see what I can do.  thanks to all  :y
