Author Topic: LPG conversion questions  (Read 5054 times)
VX1
  • Reading, Berkshire
« on: 23 July 2008, 20:37:28 »
1. Where to buy a DIY lpg conversion kit (complete inc Tank)
2. How much for the complete kit?
3. Any recommendations as to what kit?
My mig has done 118000 miles and have considered having the conversion done. Finances are not the best in the world for me so the flexiable friend will come in and pay for the kit. I don't know if its worth doing as the mileage is so high, I might be wrong, but I am sure I will be told otherwise. IF I do decide to have the conversion done I would like to have some help as I wouldn't know where to start. Drilling and the like in things like this do not make a perfect hole I'm afraid so this will be a must. Any suggestions and advice on this matter would be gratefuly appreciated.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
HNO3GOH
  • Somerset
  • Play time.
Re: LPG conversion questions
« Reply #1 on: 23 July 2008, 21:09:31 »
Stag is the name of the system that seems to be the one to get and i asked the question of how much and under £500 for a V6 system but that is for the front end only and NOT the tank. The price seems to be about £200 for a 90 litre tank and that will go in the back of the boot.
I have had a good look on the forum at members doing there own and have also had a very good look at an omega that has had a gas system fitted and i will be going down the DIY road. Hope this helps you but you will have to find out from the other forum members where you get the Stag system as i have not got that far yet :y
« Reply #2 on: 23 July 2008, 21:29:44 »
Get the stag kit from Jeremy at u-fit-lpg. His ebay user is u-fit (I think) but there are links to Jeremy's details on here somewhere (I'll have a look in a moment!)
You will pay under £700 for the full kit if you go for the more expensive 4-hole tank (80Litres) which isn't essential on the 3.0. I have, but only because I do a lot of miles (25-30k) and a lot of towing! When I collected my front end kit I was talking about multi-vales, as opposed to 4 separate valves, and there are apparently some new ones becoming available soon which can allegedly cope with up to approx 275bhb, so are a viable option for all Miggys!
As for the fitting... As you are only in Reading, Kevin Wood may be able to advise and possibly even lend a bit of a hand (obviously I can't say this for sure because I don't know what his time and commitments are like!!) I can almost certainly lend you a spare inlet manifold so you can install the injector nozzles in advance (on an exchange basis!)
I wouldn't worry too much about the mileage, as long as the car has been well maintained you should get at least the same again from it!! Mine's just gone past 121k and runs like new!! Also, LPG being a cleaner fuel means that the engine internals will last longer!  :y :y :y
I think there's going to be a full "how to" made up very soon, with input from all of the people who have done the DIY route. I know I'm planning to try and document some of the process when I fit mine in the next 3-4 weeks!
HolyCount
« Reply #3 on: 23 July 2008, 21:33:29 »
iirc Jeremy can be found here
http://www.lpg.myzen.co.uk/ufit/
« Reply #4 on: 23 July 2008, 21:33:57 »
Thanks... Beat me to it!!!  ::) ::) ::) ::)
HNO3GOH
  • Somerset
  • Play time.
« Reply #5 on: 23 July 2008, 21:49:19 »
I think there's going to be a full "how to" made up very soon, with input from all of the people who have done the DIY route. I know I'm planning to try and document some of the process when I fit mine in the next 3-4 weeks![/quote]
That would be great as i think i will be going down the LPG road soon myself. I said i never would again after my dads single point on a 2.0 16V 98 omega which was fitted by a company in glastonbury and was c**p.
Also i have seen on here a member has fitted the LPG filler to the towbar and i think i will do the same as it looked very tidy.
« Last Edit: 23 July 2008, 21:49:40 by cjjm26 »
« Reply #6 on: 23 July 2008, 21:49:56 »
It's not a "how-to" .. but it gives a damned good idea !!
Kevin Woods photo's :
http://www.omegaowners.com/forum/YaBB.pl?num=1216678718
As a matter of interest (perhaps) for you .. I had a profesional install of a BRC system .. £1850+VAT = £2200 ish... quite expensive I know but I had my reasons, however the results will be the same ....
Fuel costs prior to conversion - at £118.9 p/litre - about 26 p/mile
Fuel costs on LPG at 56 p/litre - about 15 p/mile
So I'm saving 11 p/mile .. about 40% !!
As an example .. last weekend trip to Huddersfield ... 195 miles £22 of gas ...
LPG is well worth doing IMHO   :y :y :y :y
« Reply #7 on: 23 July 2008, 22:00:02 »
Kevin Woods photo's
This was what I was referring to... It's the start of the how to!!  :y :y :y
trebor
  • Swindon
« Reply #8 on: 23 July 2008, 22:09:40 »
It's not a "how-to" .. but it gives a darned good idea !!
about 22mpg on gas?
« Reply #9 on: 23 July 2008, 22:27:18 »
I get about 23 mpg gas on a decent run - if I control the right boot - about 19 mpg round town/short runs and about 14 mpg when towing.
Equivalent petrol was 26 mpg on a run, 23 mpg town/short runs, 18 mpg towing.
This is a 3.2 Elite and it likes being "driven"   :)
Accurate costings right now ...
Estimated costs on petrol 26.27 p/mile
Actual costs on gas 15.5 p/mile
I run a spread sheet and input the details and always check the actual cost of petrol when I fill with gas, I'm trying to be as accurate as I can .....   sad I know
trebor
  • Swindon
« Reply #10 on: 23 July 2008, 22:32:25 »
Better than mine, but running an older system - a cross between single point and sequential (tartarini ETAGAS)
Wondering whether to go fully sequential, by changing front end
« Reply #11 on: 23 July 2008, 22:54:45 »
Early indications are mine is doing about 19-20 MPG on gas without any long runs yet so that seems to tally.
I believe Jay W is in the process of putting together a LPG conversion "Howto" document.
I must say, although I've only put 300 miles on it so far, I am very happy with the stag front end. It's impossible to tell if the engine's on petrol or gas, it's impossible to tell when it switches over to gas after a cold start and the numbers it's producing match Entwood's BRC system, which is regarded as being one of the best on the market.
trebor
  • Swindon
« Reply #12 on: 23 July 2008, 22:59:57 »
How much is a Stag front end?
« Reply #13 on: 23 July 2008, 23:03:43 »
Jeremy's kit is 495 inc vat for just the 6 cylinder front end IIRC.
I paid 700 including VAT and shipping for the front end, polyflex pipe and ifttings, 4 hole 80L tank, valves and filler.
trebor
  • Swindon
« Reply #14 on: 23 July 2008, 23:13:48 »
Very temping at that price....
