Author Topic: cutting out  (Read 6692 times)
paul.c
  • east calder scotland
  • hands off shes mine
cutting out
« on: 19 July 2008, 17:58:08 »
my car has started cutting out over the last 2 days. i changed the crank sensor about 3 months ago i cleaned out the idle control valve. last week it broke down had to get a recovery. when i got home i done a paperclip test and that showed up 73 74. mass airflow meter. got one from the scrappy and the car seemed fine. so now its started cutting out again i done another paperclip test and the only codes it shows are (12 31) which i know about. but also 135. when its about to cut out it starts running rough and the check light lights up. help :(
Re: cutting out
« Reply #1 on: 19 July 2008, 18:09:01 »
can you give a bit more info? is the prob. at tick over or at speed? do the electrics play up at all.?
didnt i see this posted a couple of weeks ago? :-/
paul.c
Re: cutting out
« Reply #2 on: 19 July 2008, 18:16:32 »
it happens at tickover and at speed have not noticed anything else apart from the check light. only the last 2 days (friday + today) so no previous thread sent. thanx
VX1
  • Reading, Berkshire
Re: cutting out
« Reply #3 on: 19 July 2008, 18:20:25 »
does it happen when you take your foot of the throttle when you go to brake when approaching junctions and roundabouts?
Paul  :y
Vx Trade club card holder
Halfords trade card holder
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: cutting out
« Reply #4 on: 19 July 2008, 18:24:17 »
Did you clean the breather jet?? Tride this with mine with the same symptoms as yours and it sorted it.
Check for air leaks in breather system too  :y
paul.c
Re: cutting out
« Reply #5 on: 19 July 2008, 18:33:23 »
car will start and drive normal for a while and then it feels like a misfire. check light comes on and it cuts out starts again same thing maybee 3 or 4 times. i gave it a big rev yesterday and it seemed to fix it for a while (coincidence maybee) spark plugs leads dispack all new.
psychnurse
Re: cutting out
« Reply #6 on: 19 July 2008, 18:35:07 »
Worse when warm ?? Ie at a junction after being driven some miles?? Sounds familiar to what i had... or similar.
paul.c
Re: cutting out
« Reply #7 on: 19 July 2008, 18:41:16 »
where is the breather jet please  :(
psychnurse
Re: cutting out
« Reply #8 on: 19 July 2008, 18:47:40 »
Its below the throttle assembely. where the small hose feeds to mate :y
paul.c
Re: cutting out
« Reply #9 on: 19 July 2008, 18:49:28 »
ill have a look soon ta
psychnurse
Re: cutting out
« Reply #10 on: 19 July 2008, 18:50:58 »
Try cleaning that mate... a guide in the maintenance section which is great. Hopoe it helps  :y :y :y
paul.c
Re: cutting out
« Reply #11 on: 19 July 2008, 20:27:24 »
sorry must be stupid or something cant find it on the car or in the maintenance section. also has anybody any other ideas. please ;)
paul.c
Re: cutting out
« Reply #12 on: 20 July 2008, 11:01:04 »
just found out the breather jet is on a 2ltr my car is a v6 so im still stuck i really need help. please any more suggestions :'( :'(
Re: cutting out
« Reply #13 on: 20 July 2008, 11:09:22 »
Going by the MAF faults originally - and I doubt it had failed - look for air leaks.
Is the tickover slightly eratic?
paul.c
Re: cutting out
« Reply #14 on: 20 July 2008, 11:21:49 »
the tick over is terrible but only when this problem appears the strange thing is the car can drive (and tickover) perfectly  for anything up to half an hour then start all this carry on. its a intermitant fault because it can clear its self. (and the check light will go out). im totally lost :(
