Author Topic: Diag Port not responing - any idea's  (Read 3515 times)
dpanic88
  • West Midlands
« on: 05 August 2008, 15:25:58 »
hi, have a omega 2001 2.2dti with the y22dth engine, engine light comes on at very low speed and turbo cuts out, then after 1-2 minutes the light goes off - when you pick up speed and the turbo kicks back in. Purchased a odbII - did not talk to car, so returned. Gave in and took it to VX today - asked them to change the fuel filter while they tested tech2. .. Tech2 would not talk to car at all ... The only thing that's been changed is added Cruise Controll stalk about 6months ago (would that matter?).
Getting the car back later - any one seen this problem before with the diag port?
Did not want to pay for an hours VX labour - is it  worth cleaning the Cam sensor?
Any way to check air sensor's ?
regards
iainb
  • West Midlands
Re: Diag Port not responing - any idea's
« Reply #1 on: 05 August 2008, 17:38:23 »
Hi Ya.
    I have seen diagnostic sockets that have been damaged due to tech's probing with the wrong tools,you could have a look at the socket and check to see if pins are inplace and in good order.
Another thought is the battery, what voltage is shown when you put a multimeter across it 12.5 is ok 12.75 good. (engine off) latest cars wont test below 12.5v.
  Clean air sensor's with carb cleaner, just dont have engine running,I also use it for cleaning breathers.......Dirty air sensor use to turn on the auto choke on Fiesta's !
Cheers
Iainb
dpanic88
  • West Midlands
« Reply #2 on: 05 August 2008, 19:24:42 »
Hi many thanks, picked up car they wanted 3hrs min labour at 85 quid per hour to look at the diag not working, I'll check over the connectors and pick some carb cleaner up. Thanks for the help, dpanic88
« Reply #3 on: 05 August 2008, 19:38:23 »
Yeah, see it a bit, the Vx OBDII connectors aren't great - rarely see trouble on other cars....
dpanic88
  • West Midlands
« Reply #4 on: 05 August 2008, 19:54:50 »
Yeh.. Plus Vx wanted 88 quid just to plug in the tech2 and give me the codes, wow it was 50 last year what an increase
« Reply #5 on: 05 August 2008, 20:43:09 »
Bloody Hell :o
    • 530D M Sport, 330i Coupe
« Reply #6 on: 05 August 2008, 20:48:08 »
Whereabouts in the West Midlands are you?
« Reply #7 on: 05 August 2008, 20:56:21 »
Bloody Hell :o
They trying to keep up with vw £117.
dpanic88
  • West Midlands
« Reply #8 on: 05 August 2008, 20:56:30 »
I'm in birmingham - near borneville choc factory - close to juction 3 of the m42.
« Reply #9 on: 05 August 2008, 21:06:26 »
I work in Redditch most of the week so if you are able to get to Hopwood Services one evening around 6pm I could give the Autoscanner a try.
Cheers
Andy
Ian_D
  • York
« Reply #10 on: 05 August 2008, 21:14:24 »
Not sure about the ecu.... But I've fixed a few 2.0dti vectra engines (pritty much the same as the 2.2dti) with cracked vacuum pipes which use to kill the turbo and put the EML light on!
Maybe worth checking them. On the vecs, the common place was on some rubber elbows that were fitted on the end of solenoid valves.
[size=12]
dpanic88
  • West Midlands
« Reply #11 on: 05 August 2008, 21:16:25 »
Hi that would be great, any day next week. Which will give me the weekend to have look at the diag port to see if there is any thing I could do saving you a wasted journey.
« Reply #12 on: 05 August 2008, 21:22:56 »
Ahhh, can't do next week as i'm working away, will be back the week after though so if you still need help then drop me a PM nearer the time we can arrange.
dpanic88
  • West Midlands
« Reply #13 on: 05 August 2008, 21:23:25 »
This is first turbo - the vac pipes , are these the breather pipes to and from the turbo ? Sorry ..
dpanic88
  • West Midlands
« Reply #14 on: 05 August 2008, 21:27:45 »
Hi , VXL V6. ..no problem will try a few things out (many thanks for the assistance for all who replied) and I'll pm you when I get back to confirm / cancel - thanks.
