Author Topic: key fob coding  (Read 4063 times)
trainmanone
  • stockport
key fob coding
« on: 06 August 2008, 13:20:33 »
any one in the manchester area with tech2?? need key fob coding to car have car pass ect
pete
what was that ??????
Re: key fob coding
« Reply #1 on: 06 August 2008, 14:06:27 »
Nottingham or Brackley are the only ones.
trainmanone
  • stockport
Re: key fob coding
« Reply #2 on: 06 August 2008, 14:10:36 »
cheers for that pete
pete
Re: key fob coding
« Reply #3 on: 06 August 2008, 16:27:33 »
You could try your local dealer and see how much they want or you could take a trip to Newent next month and get it done there ;)
trademeister
  • Rotherham
Re: key fob coding
« Reply #4 on: 07 August 2008, 00:19:55 »
Hi mate. Dont know if its the same with the omega, never had no problems with mine, but with my old vectra if you put the key in the ignition and turn it till the dash lights come on then press the lock button on the keyfob the doors should lock then unlock. Turn the ignition off then it should be programmed in. As I said it worked with the vectra but it may not work on the omega. Worth a go though. Hope this helps mate. Mark
Re: key fob coding
« Reply #5 on: 07 August 2008, 08:30:27 »
That will ony re-sync a key already programmed to the car, it wont add a new one to it.
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: key fob coding
« Reply #6 on: 07 August 2008, 17:42:22 »
Thanks to Trademeister for the tip, the keyfob never worked on my wifes  car since the day she had it.
I just tried your ignition on tip and hey presto works like a dream!
Cheers, I owe you a pint mate
Re: key fob coding
« Reply #7 on: 07 August 2008, 18:38:23 »
pete
Is wigan any good? asautocare or something like? Tech 2 for £30. Vauxhall specialist, somebody posted it on here i while ago. Worth a search maybe?
bigall
  • merseyside
Re: key fob coding
« Reply #8 on: 07 August 2008, 19:21:09 »
http://www.asautocare.co.uk/index.html  is in  :yWIDNES :y
mention OOf and should get a discount
« Last Edit: 07 August 2008, 19:22:27 by bigall »
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
Re: key fob coding
« Reply #9 on: 07 August 2008, 22:13:29 »
:-/wigan/widnes... close, is it wednesday?
Whoops.
holtender
  • Suffolk
    • 2.5 CDX Facelift
Re: key fob coding
« Reply #10 on: 07 August 2008, 23:07:09 »
Talking in the pub tonight about the ignition /fob thing and this guy leans over and said do you think it will work on my Astra?
So off we trotted to his Astra Estate and another driver can now use his Fob!
Re: key fob coding
« Reply #11 on: 08 August 2008, 09:05:03 »
I thought Astras have a similar setup to Omega, and the fob needed to be coded?  Which Astra was it?
Re: key fob coding
« Reply #12 on: 08 August 2008, 09:07:42 »
Think this is the old resync trick, ive used it on astras before as well.
Re: key fob coding
« Reply #13 on: 08 August 2008, 09:24:20 »
but poster said he got somebody else's fob to work on another car  :-/
Re: key fob coding
« Reply #14 on: 08 August 2008, 09:31:40 »
I thought he meant another driver can use his own fob?
« Last Edit: 08 August 2008, 09:32:34 by chrisgixer »
