Author Topic: TD Water Pump  (Read 3553 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: TD Water Pump
« Reply #15 on: 12 August 2008, 10:14:37 »
metal pump came from unipart supplier, will dig out the box later and post up if anyone wants to know??
Yes please - let us know ..... !
Omegatoy
  • UK
Re: TD Water Pump
« Reply #16 on: 12 August 2008, 20:10:52 »
GWP 2585 is the one!!! :y
DJ Pete
  • Chelmsford, Essex.
Re: TD Water Pump
« Reply #17 on: 15 August 2008, 09:33:36 »
Well, I got the pump from GSF - Plastic fins but never mind.
Slight problem though, the old one had completely lost its whole fin assembly which would explain the overheating, but after replacement I tried it without the viscous fan and it was still overheating, with the fan back on it sits at around 95 degrees.
Does this sound like the radiator needs flushing? Is there an easy way of doing this with it in situ? It looks far too complicated to take out.
Thanks.
platty
  • Cambridge
    • BMW 530d Sport
Re: TD Water Pump
« Reply #18 on: 15 August 2008, 16:21:11 »
I flushed mine out a little just to see what sort of state it was in, all I did was remove the small bottom hose (the one that runs from near the header tank to the n/s/r of the rad) and bunged my hose in there and flushed it up out the top hose. Then flushed the block in a similar way.
Reconnect all the pipes, fill her up and burp the air out. Mine was fairly clean but a few dregs flushed their way out.
cdbdiis
Re: TD Water Pump
« Reply #19 on: 15 August 2008, 21:35:59 »
Euro car parts sell the metal one, about 28 quid  :y
Re: TD Water Pump
« Reply #20 on: 15 August 2008, 21:36:22 »
I'd do a few flushes.  Remember, the TD does have a block drain, which is a help.
