Author Topic: TD Water Pump  (Read 3552 times)
DJ Pete
  • Chelmsford, Essex.
TD Water Pump
« on: 11 August 2008, 09:37:18 »
Hello All,
Am I better off getting a new Water Pump for my 2.5TD from Vauxhall on Trade Club, or would one of the pattern ones on eBay be better/cheaper?
Thanks in advance.
Re: TD Water Pump
« Reply #1 on: 11 August 2008, 10:30:10 »
Expensive, even at trade (not TC item).  A quality pattern should be cheaper.
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: TD Water Pump
« Reply #2 on: 11 August 2008, 10:44:25 »
£34+VAT from GSF for the BMW one - and their stuff is usually OE.
Thats for an E36 325tds/E34 525tds - guess its the same? Their part number B17027
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Re: TD Water Pump
« Reply #3 on: 11 August 2008, 10:45:54 »
Yeah, about £45 seems to be going rate for quality pattern part, eg Q&H
Vx want nearly a ton iirc :o
philhoward
  • Staffs
Re: TD Water Pump
« Reply #4 on: 11 August 2008, 10:49:11 »
Slightly OT (apologies), but I guess you know that GSF tend to get OEM stuff wherever possible (and actually say when it isn't).  Not had any bad bits from them yet..they've started to have some Vx stuff in, but mostly older 4-pot stuff so far and not too much of it either.  Worth keeping an eye out for?
DJ Pete
Re: TD Water Pump
« Reply #5 on: 11 August 2008, 20:19:38 »
The one from GSF ooks very reasonable, can anyone think of a reason why it wouldn't be suitable?
philhoward
  • Staffs
Re: TD Water Pump
« Reply #6 on: 11 August 2008, 20:39:50 »
QH list the same pump for the Omega, BMWs and also the Range Rover which also used the same engine...so looks like there's only one!
Omegatoy
  • UK
Re: TD Water Pump
« Reply #7 on: 11 August 2008, 20:51:22 »
not quite!!!! there are two pumps out there one has the horrible plastic impellor on it that always breaks, and the other has a nice  shiney unbreakable metal one!!! guess which one i have??? :y
philhoward
  • Staffs
Re: TD Water Pump
« Reply #8 on: 11 August 2008, 20:58:14 »
Should have rephrased that...only one FITMENT...I think any plastic impellor one would be rather old stock by now?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: TD Water Pump
« Reply #9 on: 11 August 2008, 22:08:23 »
Anyone know who manufactures the version with the metal impeller?
Re: TD Water Pump
« Reply #10 on: 11 August 2008, 22:12:31 »
All be same fitment, not seen one with metal impellor yet
Re: TD Water Pump
« Reply #11 on: 11 August 2008, 22:13:49 »
Actually, thats a lie, seem Omegatoy's before it was fitted.  Not as many fins, but obviously suitable still.  Came in a yellow box iirc, no idea what make though...
osealy
  • dublin
Re: TD Water Pump
« Reply #12 on: 11 August 2008, 22:52:21 »
The QH pump I just fitted had plastic fins , but fewer than the perfect pump I removed. Cost Eu 50. Made no difference to the hot running tho.
Omegatoy
  • UK
Re: TD Water Pump
« Reply #13 on: 12 August 2008, 08:31:36 »
metal pump came from unipart supplier, will dig out the box later and post up if anyone wants to know??
« Last Edit: 12 August 2008, 08:32:25 by Omegatoy »
philhoward
  • Staffs
Re: TD Water Pump
« Reply #14 on: 12 August 2008, 09:24:20 »
By the way, the pumps are £81.50 exchange direct from BMW (£62.77 trade) and carry a 2 year guarantee....
Not sure why they're exchange, though!  A remanufactured water pump??
