Author Topic: Water in rear passenger footwell....help!!!  (Read 1334 times)
loonatic
  • Gateshead, Tyne & Wear
« on: 18 August 2008, 12:19:09 »
Hello Peeps,
Anybody have any clues as to where water might be getting into my Omega Estate?
During the heavy rain recently I am getting a large amount of water gathering in the rear passenger footwell.  The most I've had is a couple of inches :o
Many thanks, Lee
Re: Water in rear passenger footwell....help!!!
« Reply #1 on: 18 August 2008, 12:22:17 »
Hi Lee,
Water in the footwell is a common Omega problem and is easily sorted. Try this
http://www.omegaowners.com/forum/YaBB.pl?num=1206287560
« Last Edit: 18 August 2008, 12:22:31 by Elite_Pete »
loonatic
« Reply #2 on: 18 August 2008, 12:35:36 »
Thanks for that...will go and give it a try now :y
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 18 August 2008, 15:51:22 »
What Pete said :y
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #4 on: 18 August 2008, 16:01:27 »
As above .... it happened to mine not so long ago  :-/
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #5 on: 18 August 2008, 18:03:49 »
And if that fails to resolve the problem (& you have a sun roof) check the N/S drain at the front.
...and if that fails to remedy it, buy your rear-seat passenger a snorkel! ;D
Agemo
  • Cleethorpes
  • Insignia
« Reply #6 on: 18 August 2008, 23:36:30 »
Totally agree, had it on two Omegas. However - he did say REAR footwell, suppose it still could be if the car was on a slope.
Proz
« Reply #7 on: 19 August 2008, 10:48:48 »
Mine was sat level in the drive ... but after some spectacular heavy rain i checked mine the next day to find my scuttle full of water and the front and rear nearside footwells wet....... ( mind you he said a couple of inches ... i never had that much )........ cleaned scuttle out and i've never had a problem since , even after more spectacular rain  :y
« Last Edit: 19 August 2008, 10:50:07 by Mark38 »
yorkshire ripper
  • leeds
« Reply #8 on: 19 August 2008, 16:17:26 »
just done mine last weekend,never knew you could have so much water in the car, both passenger front and rear footwells running with water. make sure you get a vax or similar water sucker/hoover in the footwells. mine are bone dry now even after the heavy rain this weekend :y.
think im gunna take the front seat out, lift the carpet, cut out the sound deadening and replace with new.
lee
