Author Topic: Any ideas?? (Interior Light)  (Read 3021 times)
Pete Wright
  • Folkestone Kent
« on: 17 August 2008, 21:43:38 »
Hi Everyone
Has anyone any idea what I can do with my interior courtesy light. When the door is opened the light comes on and stays on for the allotted delay time. However, when the ignition is switched on it remains illuminated. This is the same when the engine is running, if the door is opened at night the light stays on for the delay time even though the engine is running.
Is there a simple fix for this as it makes driving at night a problem if someone gets in or out.
Thanks for your help
Pete
prev, Cav SR, 2 Astra 3's, Nova Antibes, 3 Carltons, 2 Omegas, 2 Vectras, 3 Cavalier 3's, Frontera Sport, 3 Rover 800s, 2 Ford Kas, 2 Rover sd1's, Rover P6, Discovery V8.
Re: Any ideas?? (Interior Light)
« Reply #1 on: 17 August 2008, 21:45:45 »
Hi Everyone
Pete
By chance, have you done 'Hillpers boot boot' to override the safety systems related to boot opening?
Pete Wright
  • Folkestone Kent
« Reply #2 on: 17 August 2008, 21:50:44 »
Not performed a boot boot as I don't know what one is, the boot works fine but I have only had the car a couple of months so cannot guarantee the previous owner didn't!
« Reply #3 on: 17 August 2008, 21:52:28 »
Can you open the boot with the key in the ign, and by only quickly pressing button on dash?
What you are seeing is a side effect of the mod...
Pete Wright
  • Folkestone Kent
« Reply #4 on: 17 August 2008, 21:57:58 »
Yes the boot will open with the key in the ignition, is there anything I can do to reverse this?
« Reply #5 on: 17 August 2008, 22:09:25 »
do you have to press and hold the button to open boot, or just a quick press will open?
Pete Wright
  • Folkestone Kent
« Reply #6 on: 17 August 2008, 22:12:26 »
Not thought about it, I think I hold it
Pete Wright
  • Folkestone Kent
« Reply #7 on: 17 August 2008, 22:28:10 »
Just tried it, If I tap the inerior switch it doesn't work, but if I push it it does open quickly (Within a second)
« Reply #8 on: 17 August 2008, 22:33:04 »
And what year is the car?  2000 / 2001?
« Reply #9 on: 18 August 2008, 08:59:26 »
Sounds like its had the mod.  Guessing its an 2001 car...
Pete Wright
  • Folkestone Kent
« Reply #10 on: 18 August 2008, 16:55:41 »
Yes it's a 2001
What can I do to fix it?
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #11 on: 18 August 2008, 17:17:40 »
You're going to have to join together the red wire that was cut - as per here:
http://www.omegaowners.com/forum/YaBB.pl?num=1155211091 :y
« Last Edit: 18 August 2008, 17:18:24 by Tafty »
Pete Wright
  • Folkestone Kent
« Reply #12 on: 19 August 2008, 20:03:57 »
Thanks for all your help,
The car had been modified and the wire has now been re-joined an although the boot wont open with the key in the ignition, I would much rather have the interior light out when I am driviong at night.
You are the Gods of Omegas and I don't know where I would be without you all!
Thanks again! :)
Page created in 0.061 seconds with 16 queries.
