Author Topic: Engine number  (Read 2841 times)
FYS
Engine number
« on: 27 August 2008, 22:06:33 »
 Hi,
Where is the engine number hiding on my V6?
Cheers,
FYS.
FRE07962128
Re: Engine number
« Reply #1 on: 27 August 2008, 22:08:31 »
Hi,
Cheers,
FYS.
If I remember correctly it is down on the right hand side (looking from the front) of the engine. ;)   It takes some looking for with a torch though! ::)
« Last Edit: 27 August 2008, 22:08:58 by FRE07962128 »
FYS
Re: Engine number
« Reply #2 on: 27 August 2008, 22:18:51 »
Thanks, front, back top or bottom of the right hand side?
Near what easily identifiable parts?
Cheers,
FYS.
Danny
  • Wigan, Greater Manchester
Re: Engine number
« Reply #3 on: 27 August 2008, 22:20:43 »
should also be on your V5 aswell providing the original one
FYS
Re: Engine number
« Reply #4 on: 27 August 2008, 22:29:05 »
Thanks.....  I need to know where it apears on the actual engine block?
FRE07962128
Re: Engine number
« Reply #5 on: 27 August 2008, 22:30:50 »
Cheers,
FYS.
mid way up on that right side ;)   Well at least it is on mine! :)
Re: Engine number
« Reply #6 on: 27 August 2008, 22:35:46 »
on myn its near the oil filter housing on a flat 45o angled piece of casting. Slightly to the rear of the crank sensor iirc.
FYS
Re: Engine number
« Reply #7 on: 27 August 2008, 22:38:09 »
Thanks, i'll have a look in the daylight.
Cheers.
Re: Engine number
« Reply #8 on: 27 August 2008, 22:39:44 »
aw... not  so sure its the engine no. now. Might be gearbox related no. There is def a  number there on myn at least.
MutantCav
  • Gainsborough
Re: Engine number
« Reply #9 on: 27 August 2008, 22:46:46 »
Down by the oil filter there is certainly the engine type engraved i.e. X25XE or X30XE...not sure about engine number...
hotel21
  • The Kingdom of Fife
Re: Engine number
« Reply #10 on: 27 August 2008, 23:43:44 »
http://www.omegaowners.com/forum/YaBB.pl?num=1193589434
Lots of good info on the site, just needs looking in the right place....   :y
Re: Engine number
« Reply #11 on: 27 August 2008, 23:49:29 »
Bingo, but whats that hole with oil coming out of it bottom right?
Albert1
  • Herts
Re: Engine number
« Reply #12 on: 28 August 2008, 11:14:38 »
It's the engine-maker's technical helpline number.
Re: Engine number
« Reply #13 on: 28 August 2008, 15:16:54 »
Yeah, you got that right. £70 a minute 5 hours on hold to get through to india, to be told they dont make watches. Spot on!  :y
