Author Topic: Power sounder disconnection  (Read 1499 times)
robbo299
  • luton, beds
« on: 28 August 2008, 19:49:55 »
Hi, thought i would finally get round to disconnecting my power sounder today. Usual problem, keeps going off. I took the skuttle screw out and lifted up the skuttle to see what was what and saw this plug connector ( see pics ) and the horn next to the power sounder. Am i right in thinking that this connector is for the power sounder and that if i disconnect both connector and horn my power sounder will be silenced? Thanx.
Black cxd v6
  • Germany
Re: Power sounder disconnection
« Reply #1 on: 28 August 2008, 20:43:43 »
I had powersounder problems, I just disconected the connector to the black box, next to the horn . Stoped stright away
« Reply #2 on: 28 August 2008, 20:59:22 »
Yep, the power sounder is the black box next to the alarm horn unit....the other connector you show is for the kick down switch!
robbo299
  • luton, beds
« Reply #3 on: 28 August 2008, 21:16:44 »
Oooops.. better not disconnect that then ;D. Suppose just unplugging the horn connector will do the trick then. thanx. :y
« Reply #4 on: 28 August 2008, 21:25:46 »
No it wont, you need to unplug the power sounder which is next to the horn (to the right of it).
What are the symptoms?
robbo299
  • luton, beds
« Reply #5 on: 28 August 2008, 22:12:43 »
Usual problem. power sounder going off intermitantly at night, going on 30 mile round trip only for power sounder to give 3 beeps when i switch off. Been using the "cheat" method of locking car by pressing down drivers door button whilst rear door open and closing rear door just to get a nights sleep and keep the neighbours happy. I will remove skuttle tomorrow and unplug sounder connector. Thanx. :y
robbo299
  • luton, beds
« Reply #6 on: 28 August 2008, 22:17:36 »
Oh by the way, hope i am right in thinking that i can still alarm car with power sounder unit disconnected? I was told that the power sounder is only a back up in case someone tries to disconnect the  battery in an attempt to break in / steal car.
Page created in 0.062 seconds with 16 queries.
