Author Topic: adding cruise control..  (Read 4002 times)
sess
  • mansfield
« on: 23 August 2008, 23:30:30 »
hi just purchased a 2.5 cd diesel 2000 model i was wondering what i would need to add cruise control
tia
sess
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: adding cruise control..
« Reply #1 on: 23 August 2008, 23:38:58 »
tia
sess
You will find the answers here  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1197646817
sess
  • mansfield
« Reply #2 on: 23 August 2008, 23:41:13 »
cheers - thanks for quick reply
Proz
« Reply #3 on: 23 August 2008, 23:42:02 »
It depends if your car is DBW .... drive by wire  :y
Proz
« Reply #4 on: 23 August 2008, 23:48:56 »
Its really easy to do if your car is auto and drive by wire ( ive just had it done to mine a month ago )... i think its a bit more complex if its a manual but still doable  :y
« Last Edit: 23 August 2008, 23:49:39 by Mark38 »
« Reply #5 on: 24 August 2008, 09:56:36 »
ITS A DIESEL!!!!
It has cruise enabled - there will be a fault code stored saying no stalk found!
Add a stalk and all will be well  :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #6 on: 24 August 2008, 10:08:14 »
Just get the correct stalk
2 wire part No.9181012
sess
  • mansfield
« Reply #7 on: 24 August 2008, 11:31:27 »
cheers guys
MutantCav
  • Gainsborough
« Reply #8 on: 24 August 2008, 15:24:06 »
Stalk will need to be from another diesel...or maybe even a manual, think they are 2 wire too??
« Reply #9 on: 24 August 2008, 16:15:55 »
The BMW 2.5TD is pre-enabled (actually, it can't be disabled).  Just add the 2 wire cruise stalk (which is unique to the TD), and it will work.
Don't use a second hand stalk, buy new from a dealer (Approx £30 + VAT), as second hand ones don't last.
Proz
« Reply #10 on: 24 August 2008, 20:38:03 »
ITS A DIESEL!!!!
OK OK .... i didnt realise the diesels were different  ...only trying to help :-[ :-[
« Last Edit: 24 August 2008, 20:42:44 by Mark38 »
sess
  • mansfield
« Reply #11 on: 24 August 2008, 21:26:02 »
cheers mate thanks for info
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #12 on: 24 August 2008, 21:31:58 »
Oh how I wish that were true!!!
My local 'Stealer' wanted £45 + VAT for the damn thing!!!!!
Next nearest local 'stealer' wanted the same!!!!
local scrappy, £6 + vat. Been OK for a couple of months now. 'Stealers' are  the scum of the earth.....pariahs, all of 'em.
I always knew I'd inherit an estate, but I never thought this would be it!
« Reply #13 on: 25 August 2008, 12:04:27 »
My local 'Stealer' wanted £45 + VAT for the darn thing!!!!!
Only going by what my dealer charged me...
sess
  • mansfield
« Reply #14 on: 26 August 2008, 12:53:34 »
hi just to let you know been to order switch this morningand it cost £34.88  + vat  £40.98 in total should be here friday will let you know if it works
 cheers mark
