Author Topic: is standard alarm and immobiliser a 'thatcham'?  (Read 4081 times)
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« on: 29 August 2008, 12:00:59 »
PM with your requests.
Re: is standard alarm and immobiliser a 'thatcham'?
« Reply #1 on: 29 August 2008, 12:02:14 »
Yes, Cat1 I believe as well.
humbucker
  • Cambridgeshire
« Reply #2 on: 29 August 2008, 12:04:35 »
nice one. of course, i dont really know what 'thatcham' is, i just know insurers ask about it...
« Reply #3 on: 29 August 2008, 12:10:43 »
kinda irrelevent, as the insurers will know what is factory fitted
humbucker
  • Cambridgeshire
« Reply #4 on: 29 August 2008, 12:37:23 »
its always one of the options when getting an online quotation; when they ask about alarms in the drop down it says 'factory alarm/immobiliser' and 'thatcham cat 1 approved' or something like that, thought i'd check before i go for a renewal next month!
Albert1
  • Herts
« Reply #5 on: 29 August 2008, 13:36:04 »
Then you need to select "factory alarm/immobiliser" instead - otherwise you're implying it's a professionally-fitted aftermarket system that's been tested by Thatcham.  If your car got stolen, a jobsworth claims handler could kick up a fuss if you couldn't (and you wouldn't be able to) send them the certificate of fitting.
« Reply #6 on: 29 August 2008, 13:46:12 »
The Omega setup has been tested and approved by Thatcham
The immobilser meets Cat 2 and with the alarm Cat 1 is achieved.
Thatcham is for alarm and immobiliser aporoval and is not specific to the after market and hence it does NOT imply that an after market security device has been fitted :y
Albert1
  • Herts
« Reply #7 on: 29 August 2008, 15:45:48 »
I disagree strongly - if what you've said were true, what is the point of the "standard fit alarm/immobiliser" option on the quotation?
Banjax
  • Perth
« Reply #8 on: 29 August 2008, 17:13:26 »
Actually - Marks DTM is correct - the option is there as some manufacturers standard security does not necessarily meet thatcham standards or they may not have tested them yet
« Reply #9 on: 29 August 2008, 17:14:03 »
Correct!
Reality is that the insurers will be aware that the standard fit is thatcham approved though.
« Last Edit: 29 August 2008, 17:15:00 by Mark »
