Author Topic: Leaking Diff  (Read 1127 times)
Leaking Diff
« on: 10 September 2008, 16:24:16 »
My diff has oil dripping off it - it seems on a first inspection that it could be coming from where the prop from the autobox goes into the diff.
Any ideas if there's a seal etc that can be changed? :y
Also, what oil do these diff's use?
ians
  • Reading
Re: Leaking Diff
« Reply #1 on: 10 September 2008, 17:33:46 »
You should have gone to Newent James.. :-X ;)
Diff pinion seal I think it is.  But I would check the level first as it may look worse than it is.
Re: Leaking Diff
« Reply #2 on: 10 September 2008, 19:50:31 »
Not sure I fancy scrabbling under a car on a wet campsite - I'll wait till it's dry :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
Re: Leaking Diff
« Reply #3 on: 10 September 2008, 20:07:39 »
Changed mine recently - part number 9121965, £5.44 a litre on TC
Trade club card holder
Code scanner available
Dazzler
  • Haverhill, Suffolk
Re: Leaking Diff
« Reply #4 on: 10 September 2008, 21:25:59 »
Re: Leaking Diff
« Reply #5 on: 10 September 2008, 21:41:24 »
There is another way.....
Ask Mark to change it on a wet campsite  ;D
Thanks again mate, hope the hypoid smell has finally gone  :-[
Re: Leaking Diff
« Reply #6 on: 11 September 2008, 08:27:19 »
Lol, need to get the overalls out and air them as they are stinking the garage out......fortunately the last of it came out of my hair on Tuesday!
I also have a soldering iron here for you (and one for TB)  :y
Not to bad a job, 1.5 hours on a camp site and can be done without to many special tools (30mm deep socket is the only one)
Re: Leaking Diff
« Reply #7 on: 11 September 2008, 08:32:37 »
Cool, did you find that door motor as well?
I'll have to suggest the ladies get together again....whens 1/2 term  ;D
