Author Topic: 2.5 td oil leak  (Read 1438 times)
mickh
  • baston
2.5 td oil leak
« on: 09 September 2008, 18:37:33 »
hi have engine oil leaking fron the left front of undertry is there an oil cooler or any other pipes down that side that are knowen to leak or split
with thanks mick
Omegatoy
  • UK
Re: 2.5 td oil leak
« Reply #1 on: 09 September 2008, 20:14:07 »
if you mean nearside then thats where the oil cooler lives and the pipes are prone to rusting out!! better get under there and check buddy!!! :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: 2.5 td oil leak
« Reply #2 on: 09 September 2008, 21:06:44 »
Also worth checking is the oil filter base-housing to cylinder-block gasket.
This is a thin aluminium-like gasket, and it started leaking on my 'tractor'.
Got one recently from BMW dealer for 3 quid ... ! Part no. is B11.42.2.245.842
mickh
  • baston
Re: 2.5 td oil leak
« Reply #3 on: 09 September 2008, 21:11:53 »
thanks for your replys :y will look at cooler pipes
« Last Edit: 09 September 2008, 21:12:51 by mickh »
mickh
  • baston
Re: 2.5 td oil leak
« Reply #4 on: 10 September 2008, 20:47:21 »
hi cooler pipe rusted replaced with aeroquip now fine thank you for your help
mick
Agemo
  • Cleethorpes
  • Insignia
Re: 2.5 td oil leak
« Reply #5 on: 11 September 2008, 17:38:18 »
mick
I am assuming "aeroquip" is a sort of of replacement pipe , never heard of it.
