Author Topic: Key programming question..  (Read 1122 times)
Welung666
« on: 14 September 2008, 00:08:06 »
Another car I'm watching on FleaBay (98 2.5 petrol auto) and according to the RAC it can't read the key so doesn't run. Easy? hard? expensive?
« Last Edit: 14 September 2008, 00:08:22 by Welung666 »
Re: Key programming question..
« Reply #1 on: 14 September 2008, 09:09:26 »
Potentialy easy with access to a tech2.......havind said that, I would take what an RAC man said with a pinch of salt!
Welung666
« Reply #2 on: 14 September 2008, 10:47:34 »
Thanks Mark, I'll keep my eye on it.
MutantCav
  • Gainsborough
« Reply #3 on: 14 September 2008, 11:36:21 »
You not want a car that works then? lol
Liam
« Reply #4 on: 14 September 2008, 11:59:43 »
Ask seller for more info on the symptoms.
Sounds like perhaps it's cranking and not firing.  If it's really not reading the key, the engine management light would be flashing whilst it's cranking and not firing.  If there is no flashing whilst cranking it's something else.  Possibly crank sensor, as just happenned to mine, or even something like fuel pump relay (diagnose by seeing if it fires with easystart).
Liam
Welung666
« Reply #5 on: 14 September 2008, 12:11:16 »
Any car will do at the moment, just this one is cheap and if relatively easy to fix would turn into a bargain ;)
Welung666
« Reply #6 on: 14 September 2008, 12:11:51 »
Liam
Thanks Liam, I'll post him a question or 2 ;)
