Author Topic: Rear Blind Into 2002 CD ?  (Read 1651 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« on: 14 September 2008, 23:41:27 »
Can the electric rear blind be retro fitted into my 2002 CD ?  ... I may be able to get one if it can be  :y
Proz
Re: Rear Blind Into 2002 CD ?
« Reply #1 on: 15 September 2008, 19:12:26 »
Anyone ?  :-/
« Reply #2 on: 15 September 2008, 20:46:31 »
Do you have the multi-plug in the boot. Left hand side above shocker mount?
Proz
« Reply #3 on: 15 September 2008, 21:13:49 »
Yes there is an thin oblong connector there  :y
« Reply #4 on: 15 September 2008, 21:19:22 »
Wiring`s all in place then. Does the blind come with the shelf or were you thinking of cutting your existing shelf to fit  :question
Proz
« Reply #5 on: 15 September 2008, 22:29:03 »
This is what im trying to find out  ;) .... ie how much work is involved .... i can get the blind and motor but it doesnt come with the shelf ..... is there a lot of butchery involved if it has no shelf with it  :y
« Reply #6 on: 15 September 2008, 22:35:27 »
I doubt if you'd be able to make a blind & motor fit an ordinary rear shelf. You need to fit the whole thing.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #7 on: 15 September 2008, 22:49:27 »
easiest way of doing it is to try and get a complete shelf with blind, they go for up to £50.....
dependant on the age of the blind you may find you have to cut all the wires and use bullet connectors as the multiplugs are not compatible, don't worry its just a case of connecting the right coloured wires together  :y
took me about an hour to do, however i had to paint my shelf as it was a different colour to the car, that added another hour or two onto the job  ;D
here's a how to on blind removal, refitting is the reverse......in the words of the good book Haynes
http://www.omegaowners.com/forum/YaBB.pl?num=1152745304
oh and don't forget the switch, about £15 from a dealer, plugs straight in
« Last Edit: 15 September 2008, 22:51:39 by jay_w »
Proz
« Reply #8 on: 16 September 2008, 00:57:02 »
I did have a look at that guide just out of interest a while ago .... thats where i got the idea about the blind from .... will have to see if i can source the correct shelf then  :y
Page created in 0.024 seconds with 16 queries.
