Author Topic: Airbag Light Has Come On  (Read 3195 times)
MutantCav
  • Gainsborough
« on: 13 September 2008, 19:50:29 »
Ok as stated airbag light has come on (mini facelift so airbags in front seats too) could this just be wiring to the seats come loose as it wasnt on before and hasnt had a bump or something else?
How can you turn it off? Reset procedure or tech2?
Cheers, Chris.
  • Online Online
Re: Airbag Light Has Come On
« Reply #1 on: 13 September 2008, 20:08:14 »
Cheers, Chris.
Cheapo or real Tech II to read the fault code & then re-set. My Astra's air bag light was due to a faulty seat belt pretensioner.
MutantCav
  • Gainsborough
« Reply #2 on: 13 September 2008, 20:15:12 »
Fixing the fault wont just auto reset it then? If there is a code would paperclip test show it up?
« Last Edit: 13 September 2008, 20:16:03 by ShieldOfSteel »
« Reply #3 on: 13 September 2008, 20:16:29 »
Cheers, Chris.
Chris, Had this a while back, turned out that the multi-plug under the seat had loosened somehow. Pushed it back in no more airbag light :) :)
  • Online Online
« Reply #4 on: 13 September 2008, 20:18:30 »
..... Pushed it back in no more airbag light :) :)
You'd still have to reset it though ....  :-/
I fixed the fault with my Astra but the light didn't go out till it was reset, same as IrmscherKris's Omega.
« Reply #5 on: 13 September 2008, 20:22:24 »
As stated my light went out as soon as connector was pushed back in :)
  • Online Online
« Reply #6 on: 13 September 2008, 20:24:44 »
I believe you!  ;)
Just don't understand why.  :y
MutantCav
  • Gainsborough
« Reply #7 on: 13 September 2008, 20:26:55 »
Well I will have a fiddle with the plugs tomorrow and see if anything is resolved as well as doing paperclip test just to be on the safe side...you never know!
« Reply #8 on: 13 September 2008, 20:32:41 »
I don't think you can paperclip this system Chris..
« Reply #9 on: 13 September 2008, 20:38:56 »
I believe you!  ;)
Wasn`t implying you were wrong and I was right or vice versa just saying mine went out. Don`t know why either, just did. :y :y :) :)
Richie London
  • heathrow
« Reply #10 on: 13 September 2008, 20:39:57 »
mines been on for about 2 months now, cant find the prob  >:( >:( >:(
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #11 on: 13 September 2008, 20:43:32 »
When I owned a series of Citroen Xantias, 99.9% of the time it was the seat connector.  Only real cure was to solder the connections together...hopefully, VX used better connectors!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
  • Online Online
« Reply #12 on: 13 September 2008, 20:45:18 »
Any fault codes read?  :-/
« Reply #13 on: 13 September 2008, 21:09:28 »
paper clip/pedal trick only read engine ecu. Wont hurt to do it at any point, but i dont think the air bags have anything do with the engine ecu. How does the omega deal with child car seats? Does it have option to deactivate the pass side?
« Reply #14 on: 13 September 2008, 21:16:43 »
Needs Tech2 or cheapo Tec2 to reset airbag codes!
