Author Topic: Airbag Light Has Come On  (Read 3191 times)
Re: Airbag Light Has Come On
« Reply #15 on: 13 September 2008, 21:16:43 »
paper clip/pedal trick only read engine ecu. Wont hurt to do it at any point, but i dont think the air bags have anything do with the engine ecu. How does the omega deal with child car seats? Does it have option to deactivate the pass side?
AFAIK unable to deactivate individual aspects of SBS. IIRC if any part of SBS system inoperative light will come on :)
Tafty
  • Liverpool
  • This week I am no longer the owner of a miggy!! :(
« Reply #16 on: 13 September 2008, 21:19:01 »
..... Pushed it back in no more airbag light :) :)
You'd still have to reset it though ....  :-/
I fixed the fault with my Astra but the light didn't go out till it was reset, same as IrmscherKris's Omega.
As stated my light went out as soon as connector was pushed back in :)
Same with mine eventuallyafter I had unplugged and reconnected a few times the light went out - hasn't returned ...........yet :-X.
Taxi_Driver
« Reply #17 on: 13 September 2008, 21:51:35 »
You really need to get it tech2'd or cheapo tech2'd to find out why the airbag light has come on.........could be any of the airbags or sensors with a prob or indeed a bad connection.......but getting the code will point you in the right place  :y
« Reply #18 on: 15 September 2008, 08:37:07 »
Real tech2 is best for this...
It will show you the live data, you can then wiggle all the plugs and work out exactly which one is being a pain.
On mine it was the one in the drivers seat back, ended up giving the connector a good clean, been fine since.
bappy
  • HAVANT, Hants
  • Don't fart on the leather upholstery!
« Reply #19 on: 15 September 2008, 14:07:43 »
mine has just come on immediately after having the dashboard out for bulb replacement. maybe bashed the inside of the steering wheel bits???
If at first you dont succeed, Rev it harder!
« Reply #20 on: 15 September 2008, 20:36:24 »
Months its been out since fixing it....
Tell you how to do the same....
Bloody things come on again tonight  >:(
iainb
  • West Midlands
« Reply #21 on: 15 September 2008, 21:06:54 »
I would look around the hindge area of the seat and see if the wires have got trapped .
I dont think you will be able to turn SRS lamp off as this a safety crical system.
 There will be a stored code in SRS module
bappy
  • HAVANT, Hants
« Reply #22 on: 16 September 2008, 13:28:54 »
have thought of an alternative solution...
take butter knife to the centre dash airvents, removing them.
undo 2 screws in the corners of the air vent, remove casing...
undo screw on the left hand side of the dash panel
undo screw just above settering wheel at the base of the dash panel.
remove dash panel being careful of the fat cable in the back of the lcd screen.
locate airbag bulb on the reverse of the dash panel. turn bulb 90 degress and remove.
reassemble dash. reassembly is the reverse of disassembly.
 :D :D :D
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #23 on: 16 September 2008, 13:37:42 »
Are not the airbags inoperative if the light is showing? Taking the bulb out won't alter this, surely, and there must be insurance complications if the system has been left unrepaired or deliberately disabled.
« Reply #24 on: 16 September 2008, 13:56:44 »
The airbag ECU monitors the system whenever the car battery is connected and disturbing any part of it will raise a fault and light the light. I suspect it's detected the removal of the dash (disconnection of the airbag warning light) and now needs resetting.
JohnM
  • Newark on Trent
    • 2.5M Estate
« Reply #25 on: 16 September 2008, 20:12:09 »
Yes this is right.
Light on, no SRS (none).
If the OP doen't know what has caused it (aka self-inflicted) get a full code read to pin point for repair.  If you can't get to a friendly tech2 some auto electician specialists can read & reset (worth phoning around).
