Author Topic: Cruise servo box types  (Read 4823 times)
The Barge Captain
« on: 17 September 2008, 13:05:34 »
I've been in touch with Mutantcav about a replacement cruise servo unit (the box that is on the inner wing and connects to the bowden cable on the throttle body)
He says there are different part numbers for prefacelift long and short plenums, and another number for facelift versions!
Is there really any difference?  I only need one as the ribbon inside mine has snapped so only need to replace the box
hotel21
  • The Kingdom of Fife
Re: Cruise servo box types
« Reply #1 on: 17 September 2008, 14:37:02 »
As far as I know, the boxes are the same.  Its the length of the bowden cable thats different....
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
« Reply #2 on: 17 September 2008, 14:39:53 »
yep they are different for pre and post facelift and i think also for auto and manual.
I would only go for like for like personally - otherwise its going to be more difficult to work out if theres a fault or a compatibility issue if it doesnt work.
« Last Edit: 17 September 2008, 14:40:48 by Markiec »
« Reply #3 on: 17 September 2008, 15:37:00 »
According to EPC :
there were 4 different types, which all came with the correct cable, now just 2...
post and pre facelift
you then order the correct cable
3 different 2.0 litre cables
1 for 2.5
1 for 3.0
on the lookout for a cheap 3.0 manual kit as well (stalk, brake & clutch switch, plus obviously actuator and cable).
Cant see me matching the 99p I managed to win one for last time  :'(
« Last Edit: 17 September 2008, 15:37:36 by jimbob »
The Barge Captain
« Reply #4 on: 17 September 2008, 17:38:57 »
Well the bowden cable is ok, it's just the internal ribbon in the box that is FUBAR
