Author Topic: middle plug well full of oil(advice please)  (Read 3431 times)
craig
  • north wales/connah's quay
« on: 20 September 2008, 19:26:04 »
my v6 mini-facelift has been running bad for about 2 weeks now,missing,using alot of fuel,so i thought that it could of been the leads/spark plugs so i asked for advice about whether to buy some and some of you fellow oofers told me not to bother buying any until i checked the plug wells for oil!!!well i did today and only the middle one one the drivers side was full of oil ;) so after poking around on the forum alot of people have said that it could be caused by a breather blockage or the cam cover gasket so i was wondering what i should do please???? ::)change the gasket first or try cleaning the breathers or do both :-/
thanks in advance for your advice :y :y
« Last Edit: 20 September 2008, 19:45:51 by silvergsi24v »
Re: middle plug well full of oil(advice please)
« Reply #1 on: 20 September 2008, 19:27:23 »
Cam cover gaskets and breathers. Do asap. Guide in Maintenance if unsure :y
iainb
  • West Midlands
« Reply #2 on: 20 September 2008, 19:32:50 »
Both at the same time.
craig
« Reply #3 on: 20 September 2008, 19:37:52 »
And is there anywhere that i can buy the o-rings from on a sunday?? :y do vauxhall parts open on sundays?????
« Reply #4 on: 20 September 2008, 19:41:16 »
nowt after 12:00 Sat around here....
« Reply #5 on: 20 September 2008, 19:41:57 »
erm... hang on a mo....
« Reply #6 on: 20 September 2008, 19:44:07 »
guess what im holding ;)
craig
« Reply #7 on: 20 September 2008, 19:44:28 »
ignore your pm mate ::) ;D ;D :y
craig
« Reply #8 on: 20 September 2008, 19:48:24 »
the keys for lookers chester?? ;D
« Reply #9 on: 20 September 2008, 19:48:42 »
if its...
1 x 90467543 -
6 x 90500983
then I can sort you out.
craig
« Reply #10 on: 20 September 2008, 19:51:46 »
if its...
1 x 90467543 -
6 x 90500983
how can i find if these are the right ones mate ::)
and how much if they are please ;)with local discount ;D :y
« Reply #11 on: 20 September 2008, 19:51:56 »
a short drive through the lanes will get you a set
if ya want em, lemme know, and ill pm my address.
then just pick a new set up and drop em off when you can, no idea how much they were, invoice in little fella's (fast asleep) bedroom
« Reply #12 on: 20 September 2008, 19:54:06 »
EPC calls em  :
O ring, extension, adaptor, engine ventilation
O ring, crankcase ventilation.
I'm sure I bought 2 sets when I did hers, this set currently awaiting use.
craig
« Reply #13 on: 20 September 2008, 19:55:01 »
Are you sure you don't mind mate??when?? :y
« Reply #14 on: 20 September 2008, 19:55:52 »
now?
