Author Topic: Broken Front Spring!  (Read 4117 times)
  • Online Online
« on: 17 September 2008, 19:29:56 »
I was investigating an on/off rattle from the front nearside and discovered that the bottom section of the spring has snapped off!! Its the very bottom coil and judging by the rust its been like it for some time.  Does anyone know how much they are?  and are they difficult to change?
Also I've noticed that the inside edge of the front offside tyre is worn and I read somewhere on here that the camber needs resetting?  Would the broken spring affect the camber so the tyre is wearing??
Thanks in advance for any advice!!
Steve
Re: Broken Front Spring!
« Reply #1 on: 17 September 2008, 19:45:09 »
The broken spring is likely to affect camber.
Its VERY rare for front springs to break.....so you could go second hand or try ringing these boys as they sell KYB ones:
www.suttonautofactors.co.uk
  • Online Online
« Reply #2 on: 17 September 2008, 19:56:11 »
Thanks for your reply.  I'm guessing that if I put a new spring on, I'd be best off changing both sides so both springs are the same height?
« Reply #3 on: 17 September 2008, 20:58:53 »
ALLWAYS .. but ALLWAYS change suspension components in pairs .. you are just asking for major handling/tyre wear problems otherwise
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #4 on: 17 September 2008, 21:15:52 »
very very good advice :y
might be worth changing dampers (depending on condition) at same time if you've got struts apart to change springs - especialy if they'll need doing soon, otherwise you'll end up paying for the camber to be set up twice ;)
Nova SR, MKII Cav Sri130, MKII Astra GTE16v, Omega 3.0V6 Elite, Silver Cross Sleepover Classic
« Reply #5 on: 17 September 2008, 21:25:35 »
why do rear springs fail quite often, but rarely the fronts?
Is it because they are more exposed to the elements  / road much at the back  :-/
  • Online Online
« Reply #6 on: 17 September 2008, 22:56:08 »
Thanks for all the advice guys!!
Can anyone recommend a decent workshop manual for the 2000 2.5V6 CDX.  As far as I can see the Haynes manuals only go up to 1999, but did they change that much??  What about the CD rom manuals on Ebay??
Cheers again!! :y
Welung666
« Reply #7 on: 17 September 2008, 23:18:17 »
The one I got ain't bad at all, I'll do you a copy save you fleabayin' if you like.
  • Online Online
« Reply #8 on: 17 September 2008, 23:23:11 »
That would be great thanks!! :y
Can you email it or is it on CD only??
Welung666
« Reply #9 on: 17 September 2008, 23:24:43 »
Discussing duplication of copywtite materials etc is not permitted on open forum....  :'(
H21
« Last Edit: 21 September 2008, 15:09:08 by hotel21 »
  • Online Online
« Reply #10 on: 17 September 2008, 23:31:54 »
Whatevers easier for you!
Welung666
« Reply #11 on: 17 September 2008, 23:33:19 »
I'll do it tomorrow after work and send you a PM  :y
  • Online Online
« Reply #12 on: 17 September 2008, 23:40:22 »
Thats great thanks!!  Better get those springs and hope the weathers good at the weekend!!  ::)
Cheers :y
sev
« Reply #13 on: 18 September 2008, 16:13:26 »
Its normally because they're the driving wheels. All the load goes through those springs when you accelerate.
1995 2.5 V6 CDX Saloon
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #14 on: 20 September 2008, 19:37:08 »
Discussing duplication of copywrite materials etc is not permitted on open forum....    :y
Discussing duplication of copywtite materials etc is not permitted on open forum....     :y
 I've got a 2001 V6 CD 24v. Thanks
« Last Edit: 21 September 2008, 15:10:26 by hotel21 »
If it ain't fun, it ain't worth doin
