Author Topic: Crank shaft senror life  (Read 1338 times)
chrisdb
  • Chesterfield
« on: 02 October 2008, 12:57:56 »
I was browsing the tech info section and noticed in the sensors post that the crank shaft sensor has a life of about 100k. As my car has done this now, is it worth me changing it before it gives up?
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
Re: Crank shaft senror life
« Reply #1 on: 02 October 2008, 13:02:06 »
I would just keep an eye out for a code 19, check ours at least every month, tyres, oil, washer fluid, fault codes etc
chrisdb
  • Chesterfield
« Reply #2 on: 02 October 2008, 13:04:30 »
Great idea! I normally only check the codes after a fault but it makes sense to check and pick up stuff early.
Thanks
« Reply #3 on: 02 October 2008, 13:14:30 »
yup, and many faults not deemed serious enough, like crank sensor, to illuminate the bulb  :-/
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #4 on: 02 October 2008, 13:22:34 »
What causes the failure of this sensor? It's only a simple capacitive sensor and in general they are extremely reliable in all other industrial use; why no tin Omega? Too hot place? Too much bathing in hot oil? Too cheap sensor? Anyone have any idea?
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 02 October 2008, 13:25:32 »
its not a capacitor its a Hall sensor uses a magnetic field i believe and magnets wear out!
it also doesnt help that the sensor wire runs past the exhaust manifold
Martin_1962
« Reply #6 on: 02 October 2008, 13:31:48 »
The wire gets cooked - find out which version and buy a spare
« Reply #7 on: 02 October 2008, 16:56:13 »
not that expensive to wait for trouble..I changed..
