Author Topic: Fitting cruise control?  (Read 2933 times)
manny
  • bromorough.Wirral.
« on: 03 October 2008, 00:04:24 »
Ive read on the oof that to fit cruise you need to replace indicator stalk and then have a vauxhall dealer activate it?Then ive read you need to fit switches on the clutch and brake peddle ect???Can anyone put me clear on this one.Thanks. :y
2001 OMEGA MV6
manny
Re: Fitting cruise control?
« Reply #1 on: 03 October 2008, 00:28:22 »
Just read that you only need to fit stalk and thats it?
2001 OMEGA MV6
Miggy24
  • Exeter,Devon
« Reply #2 on: 03 October 2008, 08:00:50 »
Hi mate if you read the post i put up someone told me how to see if the car can have cruise control
« Reply #3 on: 03 October 2008, 08:28:59 »
His is drive by wire, yours is cable operated.
So Manny
Yes
Fit New indicator stalk with cruise,
check and fit brake and clutch switch's if necessary, have a chat with tech2 to enable it all.
There are cheaper places than dealers ;)
« Last Edit: 03 October 2008, 08:29:39 by jimbob »
« Reply #4 on: 03 October 2008, 09:00:09 »
2.6 manual will have brake switch fitted.  From memory, clutch switch won't be, so check that.
Then stalk (£30 from dealer), and a chat with a tech2 device...
manny
« Reply #5 on: 03 October 2008, 20:10:42 »
Do you need to fit the clutch switch for it to work?
2001 OMEGA MV6
achoo81
  • Exmouth Devon
« Reply #6 on: 03 October 2008, 20:18:26 »
Yes you do coz it won't work without it.
Onkel Per
  • Frederikshavn - Denmark
« Reply #7 on: 03 October 2008, 20:20:19 »
Yes, you need to fit the clutch switch for it to work.
The clutch switch is on/connected until you press the clutch, then it's off/disconnected.
So without the switch the connection will be off all the time = disable the cruise control.
manny
« Reply #8 on: 03 October 2008, 20:20:46 »
So i need a new stalk,clutch switch and then a visit to a tech 2?
2001 OMEGA MV6
« Reply #9 on: 03 October 2008, 20:55:50 »
Yes.
« Reply #10 on: 03 October 2008, 22:28:05 »
Visually check for clutch switch before buying new one :y
NickA
  • Cambridge
« Reply #11 on: 04 October 2008, 18:09:53 »
My facelift 2.6 had the clutch switch already fitted so it just needed a new stalk and tech2ing
puffa
  • Southampton, UK
« Reply #12 on: 04 October 2008, 18:33:17 »
no one has checked the most important thing,, is the cruise control unit actually fitted, cause if not it wont matter how many switches you change or the indicator stalk being changed it simply will not work,, now it may be that all facelifts have the unit fitted,, however on my previous miggy it was quoted at nearly £900 all in and simply not worth it....
Previously owned 2.5 v6 Reflection
« Reply #13 on: 04 October 2008, 18:41:53 »
No unit required on drive by wire throttle cars (i.e. 3.2, 2.2 and 2.6) as its nothing more than a software setting in the engine ecu  :y
« Reply #14 on: 04 October 2008, 18:51:03 »
as mentioned 2.0 / 2.5 / 3.0 have a cable linked to the throttle, so its very much a physical process, hence the unit required.
2.2/2.6/3.2 the engines throttle is controlled by the ECU, no cables involved. Hence its just a software adjustment.
