Author Topic: Lost my climate - wiring diagrams needed please  (Read 4990 times)
JasonH
« on: 11 October 2008, 17:55:09 »
Still battling my code 87.
Seems I have lost power to a whole bunch of relays controlling air con and radiator cooling fans.
They should all have power from Fuse 15.
But most things on Fuse 15 are fine, apart from the stuff under the bonnet.
I desperately need:
1) The location of connector X5
2) A facelift wiring diagram - I think my Haynes wiring diagrams may be misleading me.
So far I've had virtually the entire dash out - what a nightmare....
Re: Lost my climate - wiring diagrams needed please
« Reply #2 on: 11 October 2008, 18:58:10 »
not the first time the book of lies led someone astray...esp. as its for pre face lift :(
JasonH
« Reply #3 on: 11 October 2008, 19:03:14 »
Thanks TheBoy.
Have you any for the radiator cooling fans and air con compressor.
K60 is the centre of my investigation.
« Reply #4 on: 11 October 2008, 19:07:30 »
same place, but its for 2.6/3.2. Only 2.5 I have is Haynes.
JasonH
« Reply #5 on: 11 October 2008, 19:36:43 »
Anything you've got would be really helpful - I'm completely stuck at the moment.
There's a bunch of relays that control the fans on the front of the radiator and aircon compressor. According to haynes they should all get 12V when the ignition is on via fuse 15. Fuse 15 is fine and so is all the cabin stuff that runs off fuse 15.
Trouble is no power to the engine bay relays - which the ECU picks up on and flags error 87.
I think there might be another relay or something on the facelift. So any facelift wiring diagrams would be great. The one you gave me gives me all the stuff directly off the ECC but not the compressor and additional cooling fan relays, fuse etc.
« Reply #6 on: 11 October 2008, 19:48:45 »
You haven't checked that download location ;)
markey mark
  • SLady bitshorpe north lincs
« Reply #7 on: 11 October 2008, 19:49:49 »
put you own live there to prove it works then trace wire back to fuse box !  :y
« Reply #8 on: 11 October 2008, 19:49:49 »
All those relays feed by fuse 29, 12v with ign on.
« Last Edit: 11 October 2008, 19:49:58 by TheBoy »
JasonH
« Reply #9 on: 11 October 2008, 19:50:29 »
Thanks again, didn't quite get the jist of your reply and replied before clicking on link again.
Got the file now - cheers.
JasonH
« Reply #10 on: 11 October 2008, 19:52:09 »
Plan to put my own live there as next step - but need to be certain working on the right diagrams so I don't smoke something expensive.
JasonH
« Reply #11 on: 11 October 2008, 19:54:32 »
It's a black feed wire at when no power reads 68 Ohms to ground. Traced it through engine bay.
Glovebox out, centre panel out can't figure out where it's coming from.
JasonH
« Reply #12 on: 11 October 2008, 20:02:53 »
F**k me.
TheBoy you're a star.
Spent the whole day pulling my car to pieces and you've nailed it in 2 mins. Fuse 29 was the problem.....
Will have to put it all back together tomorrow....
« Reply #13 on: 11 October 2008, 20:19:30 »
Result :y
