Author Topic: Switchgear - interchangeable with other VX's?  (Read 1753 times)
TECHNOPUG
  • Islington - London & Essex
« on: 17 October 2008, 14:37:53 »
Need to get the car MoT'd (well, a couple of weeks ago probably) and I believe that I need to replace the indicator/lights switch. It all works, however the full beam doesn't click "on" - you have to keep the switch pulled back. I presume an MoT failure? There is grinding behind the wheel on hard lock, so I presume that a plastic catch has just snapped off.
  Soooo......can the switchgear be sourced from other VX's or is it Omega specific? Obviously don't want to pay stealers prices so would be going on a scrapyard hunt.
Cheers,
Andrew
Re: Switchgear - interchangeable with other VX's?
« Reply #1 on: 17 October 2008, 14:40:10 »
That is unfortunately a common fault on 2nd hand stalks, and why new are often recommended when fitting cruise.
Would appear they dont like being distrubed.
should be plenty 2nd hand ones about from people who have added cruise..
« Reply #2 on: 17 October 2008, 14:41:40 »
hang on, you pull the switch back to flash...push it forward to lock on....
« Reply #3 on: 17 October 2008, 14:44:05 »
I bought a non gen cruise / indicator stalk of ebay, cheap enough but doesnt 'lock' very nicely for the indicators, cancels far too easily
loads on ebay for about a fiver though....
« Last Edit: 17 October 2008, 14:44:44 by jimbob »
TECHNOPUG
« Reply #4 on: 17 October 2008, 14:46:40 »
WTF?!?!? Really? Doh.........err.....hmmmmm.....OK.....will have another look tonight. Years of driving Pugs I'm afraid!
« Last Edit: 17 October 2008, 14:48:26 by TEKNOPUG »
TECHNOPUG
« Reply #5 on: 17 October 2008, 14:51:25 »
On another MoT related note: will a slight missfire under load due to cam-cover seals needing replacing be a fail? I guess that they aren't likely to drive it! So.....oil in the plugs a failure? It doesn't smoke so hopefully emissions will be fine! Hopefully then all I need to do is fix the clattering exhaust.
Martin_1962
« Reply #6 on: 17 October 2008, 16:55:38 »
New one from the dealers, not that expensive and they all wear out
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #7 on: 17 October 2008, 17:08:29 »
Cheers,
Andrew
if its the non-cruise control one your after then you can have mine for postage as im upgrading to cruise so wont need it.
let me know if you want it
V8!!!!
TECHNOPUG
« Reply #8 on: 20 October 2008, 10:11:13 »
Cheers,
Andrew
Thanks for the other but I discovered that pushing the switch forward does indeed turn the lights to full beam.....must have been having a very blonde moment!
« Reply #9 on: 20 October 2008, 10:31:43 »
LOL
nice easy fix then ;)
JesterRT
  • Stafford
« Reply #10 on: 20 October 2008, 12:49:33 »
...and if you'd gone to the stealers they'd have still probably charged you £80 for the privilege.   :)
I like the easy fixes!
