Author Topic: wishbone change - new bolts?  (Read 1292 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 19 October 2008, 09:55:15 »
Hi all,
I know in the how2 it says to change the bolts but I was in the process of changing the drop links which were far too easy compared to the steering idler yesterday >:( which was a bit of a pig.  So I was looking at these new wishbones I have to put on and thought I could have a go at that today....
...but I dont have the new bolts.... is it that crucial or can I get away with reusing the old ones.  :-/
All opinions welcome  :y
Re: wishbone change - new bolts?
« Reply #1 on: 19 October 2008, 10:00:11 »
I used to, as I tend to buy some with wishbones, but its not necessary.
When Marks DTM rebushed my MV6 ones a couple of months back, we reused old bolts.
Gaffers
« Reply #2 on: 19 October 2008, 10:05:49 »
sweet!  off back out now..... :D
« Reply #3 on: 19 October 2008, 11:32:42 »
Nope, as they are angle torqued but not to the point of yield (like head bolts are0....
Gaffers
« Reply #4 on: 19 October 2008, 12:45:33 »
one side done, a bit fiddly to get the rear bush in place but its all back now.  Hopefully get no more knocking sounds  :y
manny
  • bromorough.Wirral.
« Reply #5 on: 19 October 2008, 14:13:39 »
Hi all,
What made the idler a pig of a job as im doing mine in the next couple of weeks?
2001 OMEGA MV6
manny
« Reply #6 on: 19 October 2008, 14:14:47 »
Hi all,
What made the job a pig as i plan to do mine ????
2001 OMEGA MV6
Gaffers
« Reply #7 on: 20 October 2008, 08:38:31 »
Hi all,
The difficult part was getting the ball joint thread to stay put as the old nuts came off and the new plastic topped nut went on.  I found a monkey wrench was best with just the right amount of grip so as not to kill the ball joint gaiter.  But it was quite fiddly.....  >:(
WRT to the wishbones.  I completed them last night after a few distractions.  The left (ns) hand drop links came out easy and the wishbone was tough to get out but putting the new one in was a peice of pish.  On the other side the drop links were a bit of a bugger but came out evenually, whereas the drivers side rear bush had somehow gotten trapped at an angle in the bolt hole.  This made extraction difficult but after a bit of gentle pursuasion it came free.
The really difficult part was next. Getting the rear bush aligned properly and the bolt into the hole.  I got the holes lined up as much as possible - this required going right underneath the car, dont do this unless you have lots of axel stands supporting the car at various points.  I then fashionned a dropper out of a wire coat hanger and fed it down through the engine bay as close as I could to the hole.  Using the front bush bolt I then wiggled the bush until the bolt started to drop into the bush and then followed it up using bar extensions and a hammer to tap it home.
Just waiting to get the car geometry setup now after a very rewarding weekend's work  :y
Markjay
  • London
« Reply #8 on: 20 October 2008, 16:01:03 »
In would have changed the bolts, just because TIS2000 says so. But the local dealer did not have them in stock, so I was about to change the wishbones and re-use the old ones (as the government would say, this is NOT a U-Turn. I have always said clearly that I will either re-use the bolt or not, as the case may be. Clear as mud, that is...). Then I sold the car before having a chance to fit the new wishbones, which I believe are now on Mike Dundee's car... does this help? er..not really I guess...
Alas, no more Omegas....
Page created in 0.031 seconds with 20 queries.
