Author Topic: Brake Sensor - again  (Read 1023 times)
Malabo
  • Sherburn in Elmet
« on: 22 October 2008, 19:56:47 »
Hi, got some sensors form dealer - shafted @ £30 for the pair. Anyway, some one at weekend said, why don't you just unplug them? -They are only there for people who don't bother to check pad wear!
I asked, won't that indicate a fault that they are disconnected. I was assured it wouldn't. Just sounds too easy to unplug them. Will it / won't it?
Having new pads and discs fitted by previous owner but bake pad warning on dash, would an MOT tester fail brakes cos this warning is present?
Thanks
Malcolm
Re: Brake Sensor - again
« Reply #1 on: 22 October 2008, 20:34:23 »
Pretty sure unplugging will register as a fault....
But cutting the old sensor off the end, and joining the wires together wont ;)
« Reply #2 on: 22 October 2008, 20:45:11 »
now this is a bit vague, but first time i did my breaks, i did not know about the sensors, and boke them, or one at least. i had to reassemble breaks, with one missing, go buy sensors. re fitted, re assembled. i have never seen a brake pad warning on a mig. Dont know what one looks like. :-/
« Reply #3 on: 22 October 2008, 20:50:01 »
And £7 each if you get access to Tradeclub (£20 per year)
« Reply #4 on: 22 October 2008, 23:53:29 »
I asked, won't that indicate a fault that they are disconnected. I was assured it wouldn't. Just sounds too easy to unplug them. Will it / won't it? .......
Yes it will register as a fault. They see a fault when the sensor sees an open circuit, ie when the disc wears through  the sensor. You can of course, cut the ceramic bit off the end & join the two wires togther to turn the ligh off. You're then back to the old fashioned way of looking at your pads every now & then.  ;)  :y :y
Malabo
  • Sherburn in Elmet
« Reply #5 on: 23 October 2008, 09:31:21 »
Thanks for that guys, just until I can get round to fit the new sensors I'll make ot see a cpmplete curcuit
