Author Topic: EML on all the time  (Read 2338 times)
GEDFORDM6
  • Cleveland
EML on all the time
« on: 19 October 2008, 14:35:32 »
Hi,just changed cam cover gaskets,spark plugs and leads on 3L V6 and have now got it running after a mix up with firing order(thanks for the help here,great site). I now have a permanent EML,never had one before work and have checked all connections.Could it be the misfires recorded during ht mix up?How do I get rid of light?Thanks in advance.
Re: EML on all the time
« Reply #1 on: 19 October 2008, 14:37:06 »
If it's a 3.0 paperclip test it... guide in the maintenance or technical section here... :y
« Reply #2 on: 19 October 2008, 14:37:40 »
Paperclip to see if any codes are coming up first :)
« Reply #3 on: 19 October 2008, 14:38:26 »
Beat me by milliseconds James ;D ;D
« Reply #4 on: 19 October 2008, 14:40:40 »
paperclip test below
fill in your profile so we know what car you have
probably something trapped or onplugged
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
oh and welcome by the way :y
« Last Edit: 19 October 2008, 14:41:55 by chrisgixer »
« Reply #5 on: 19 October 2008, 14:41:27 »
Check also to see if knock or cam sensor wires trapped under camcover :)
ballcock50
  • South Wales
« Reply #6 on: 19 October 2008, 14:44:27 »
I mixed up two connectors on the air inlet once air temp sensor with some thing else (same plugs) could not figure what was wrong. this gave eml light on
GEDFORDM6
  • Cleveland
« Reply #7 on: 25 October 2008, 18:53:43 »
My car is a 1995 3.0l elite,not sure how to add it to my profile! I have checked all connections and nothing is trapped under the cam covers.Done paper clip test and got the following codes 14  145 144 82  83  19    I dont think the engine is as smooth running as before and wondering if the firing order is still wrong and causing these fault codes ?Does anyone have a picture of position of HT leads as if you were looking at the DIS through the passenger glove box.Thanks,Ged..
« Reply #8 on: 25 October 2008, 19:02:56 »
Right, did you disconnect the leads from the injectors.....or did you use the large multiplug.
If you did the former, check they are plugged back on correctly (a common mistake!)
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #9 on: 25 October 2008, 19:10:49 »
Here you go
« Reply #10 on: 25 October 2008, 19:19:34 »
Here you go
Thanks Timbuk, without knowing it you have solved a querry I had that even my local Vx dealer could not answer from looking at their system! ::) ::) :y :y :y
Timbuk
  • Telford
« Reply #11 on: 25 October 2008, 19:23:10 »
Here you go
Nothing new there then  ;D
« Reply #12 on: 25 October 2008, 19:43:16 »
Here you go
They cant have been looking very hard then!  ;D
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #13 on: 25 October 2008, 20:19:13 »
If you did the former, check they are plugged back on correctly (a common mistake!)[/quote]
Oh yes i know about that  ::) ::)
