Author Topic: Rear Springs Advice  (Read 903 times)
sub24
Rear Springs Advice
« on: 27 October 2008, 14:37:17 »
About 18 months ago i changed the rear springs on my 2.6 CDX as they have both snapped.
I bought cheaper ones off of ebay and fitted these.
They seem to have gone soft rather quickly and the car although okay now sits a lot lower at the back than it used to.
Any advice on if its worth getting new srpings again and paying for the Vauxhall ones - Or can anyone recommend a decent replacement.
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
Re: Rear Springs Advice
« Reply #1 on: 27 October 2008, 14:46:18 »
you could stick in a pair of graystons size 15 spring assisters and raisers (about 20-25 £ a pair)
i use them as i tow a caravan  they should stop the sagging
dieseldonicely
« Reply #2 on: 27 October 2008, 16:49:28 »
are you sure its the springs, and not just knackered shocks?
sub24
« Reply #3 on: 27 October 2008, 17:14:19 »
Might give the spring assisters a go.
Are they easy to fit
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #4 on: 28 October 2008, 22:50:04 »
I think it's a case of jacking it up so the wheels are off the deck, fairy liquid to lubricate the assistors and slip them on. Not done it myself but was advised by an MOT examiner.
One thing though, if the ride height is not correct it will affect the camber and you'll wear the tyres on the inside edge if too low and the outside edge if too high.
Page created in 0.008 seconds with 16 queries.
