Author Topic: omega using alot of oil  (Read 1501 times)
Miggy24
  • Exeter,Devon
« on: 06 November 2008, 14:49:49 »
Hi all since iv had the omega its been fine but over the last week or too its been using alot of oil and the drive dont feel right its not as smooth.theres no white mayo on the filler cap or on the dip stick anyone on wot it can be
Re: omega using alot of oil
« Reply #1 on: 06 November 2008, 14:51:46 »
Any smoke. Any leaks :question Check plugwells for oil :)
« Last Edit: 06 November 2008, 14:54:18 by RobG »
Miggy24
  • Exeter,Devon
« Reply #2 on: 06 November 2008, 14:55:18 »
i have seen it smoke every now and again.as for oil in plug holes will have to have alook.if there is wot does that mean
« Reply #3 on: 06 November 2008, 14:58:52 »
Camcover gasket breaked. Look here http://www.omegaowners.com/forum/YaBB.pl?num=1152565472 :y
Miggy24
  • Exeter,Devon
« Reply #4 on: 06 November 2008, 15:01:28 »
The engine in my omega is the old 2.0 8v u say the cam cover gaskit is that as in the rocker cover gaskit
« Last Edit: 06 November 2008, 15:03:57 by devonboy2008 »
« Reply #5 on: 06 November 2008, 15:10:03 »
Oil in plugwells not an issue with the SOHC. Have you checked for leaks all over :question
« Last Edit: 06 November 2008, 15:10:31 by RobG »
« Reply #6 on: 06 November 2008, 16:06:09 »
And blocked breathers which can increase crank case pressure resulting in more oil past the stem seals and rings.
Miggy24
  • Exeter,Devon
« Reply #7 on: 06 November 2008, 19:50:14 »
Ok thanks for that i`ll look at the breathers 2moro :y
