Author Topic: Coolant Warning  (Read 1572 times)
jamescropley
  • Grantham, Lincs
Coolant Warning
« on: 12 November 2008, 21:41:23 »
Iv'e just got bac in from a 20 mile drive and when i switched off the engine my dash said coolant level. It doesn't say if its low or anything. Now what is coolant level? and how do i resolve it?
Re: Coolant Warning
« Reply #1 on: 12 November 2008, 21:48:18 »
'Coolant level' means it's low .... or at least it thinks it's low. Have a look at the header tank, driver's side wing (lift bonnet first  ::)) and look where the level is relative to the line on the bottle. Be aware though that a hot engine will give a slightly lower level than if the engine is cold - the line has an arrow pointing towards it with 'kalt' (German for cold)
If it's significantly low, leave the car till the morning when it's cold & top up to the line. If it already at the line, it could be the sensor in the bottom of the header tank that's failed.
« Last Edit: 12 November 2008, 21:49:14 by Andy_B »
jamescropley
  • Grantham, Lincs
Re: Coolant Warning
« Reply #2 on: 12 November 2008, 21:50:59 »
Is that the water tank? It's the only one i can think of. I thought it was pretty full.
Re: Coolant Warning
« Reply #3 on: 12 November 2008, 21:56:05 »
It's called a header tank, yellow cap on the driver's side of the engine bay and will spew hot water out if you open it now!!  :o
If it's at or above the level line, then the level switch, which it a part of the tank is likely to be goosed. Either unplug from the switch & bridge the two terminals in the plug to turn the message off, or replace the header tank - £30-ish
jamescropley
  • Grantham, Lincs
Re: Coolant Warning
« Reply #4 on: 12 November 2008, 22:03:09 »
Thanks andy. I'll try it in the morning. I didnt want to sound thick!!
Moos3h
Re: Coolant Warning
« Reply #5 on: 12 November 2008, 22:10:50 »
Yep, more than likely the sender is full of poop that stops it functioning correctly.  Easiest just to pick up a new header tank from a breakers (or here!) and swap the whole lot as I don't think it's designed to come apart.
Cheers,
James
Re: Coolant Warning
« Reply #6 on: 12 November 2008, 22:12:22 »
If it is low and you top it up use a 50:50 mixture of water :Vx antifreeze  if you don't you gradually reduce the concentration of antifreeze and get many more problems long term .. :(
« Last Edit: 12 November 2008, 22:12:41 by entwood »
4397KENNY
  • GRANTHAM
Re: Coolant Warning
« Reply #7 on: 12 November 2008, 22:23:39 »
clarkes scrapyard has about 3 up there   :y
Re: Coolant Warning
« Reply #8 on: 12 November 2008, 22:26:21 »
For the price of a nice shiney new bottle, I'd not bother with the scrappies.
