Author Topic: Facelift dualfuel 2.2 Runs really Badly on Petrol  (Read 1376 times)
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« on: 18 November 2008, 15:56:01 »
My miggy runs terrible on petrol, lumpy tickover and doesn't respond to throttle, although on LPG it runs perfectly, where should i start looking, presuming its not ignition as LPG is ok....
Any clues or pointers please?
Omega 2.6 V6 Elite in Shiny Black
Re: Facelift dualfuel 2.2 Runs really Badly on Petrol
« Reply #1 on: 18 November 2008, 16:06:02 »
I'd say either the petrol injectors are getting a bit clogged due to running on LPG most of the time OR the fuelling on LPG is a little out, and it has "learned" this characteristic, so the fuelling goes the other way on petrol. Does it improve if you run it for a few journeys on petrol only?
« Reply #2 on: 18 November 2008, 16:07:03 »
petrol fuel filter in need of replacement?
I know a lot of lpg'ers keep their tanks very low, so may pick up more dirt?
Martin_1962
« Reply #3 on: 18 November 2008, 16:47:06 »
At least there is no issue as how often do you need to use petrol!
Clogged injectors - shove some BP or Shell stuff through, possibly injector cleaner
Italian tune up - always helps
Not fuel filter as idle is bad
Clean breathers as well
mark.adams
  • Cambridgeshire
  • Happy
« Reply #4 on: 18 November 2008, 19:49:36 »
Thanks guys,
Is that correct that if it idles rough as well, its not likely to be the fuel filter??
Could the EGR valve be a suspect, its blanked off but i do get an emissions light on every now and then?
When its being a real b@st@rd, you can put your foot down to pull away and nothing happens, it just chugs until it finally either dies or bursts into life
« Reply #5 on: 18 November 2008, 20:46:01 »
Mark .. most of your posts are unreadable due to the large size of your avatar .. :(
Martin_1962
« Reply #6 on: 18 November 2008, 21:57:20 »
What sort of LPG system is it?
Mixer
SGI?
Give it a service including plugs and take it from there
Could be airleak
