Author Topic: Key wouldnt turn in ignition.  (Read 804 times)
« on: 03 December 2008, 08:24:32 »
Iw was VERY cold this morning, windscreen frozen and refrozen.
Opened a door, put something in, shut door, it was too frozen to latch!  nearly had to tie it shut!
Anyway, key in ignition, and it wouldnt turn at all :(
Lots of jiggling, and trying with both keys.
Eventually turned, and car started fine.
Now, can i put this down to the cold, or should I be looking for a problem (before its too late?)
Cheers
« Last Edit: 03 December 2008, 08:29:27 by jimbob »
hotel21
  • The Kingdom of Fife
Re: Kew wouldnt turn in ignition.
« Reply #1 on: 03 December 2008, 08:26:46 »
Sounds like the ign lock had also frozen.
Wee squirt of deicer in, to see if it works?  May well be worth cleaning it out and a light lube with something like graphite spray, rather than WD.
Re: Key wouldnt turn in ignition.
« Reply #2 on: 03 December 2008, 08:29:00 »
was thinking about spraying a little lube in, or coating the key in lube, then few turns etc
wasnt sure if there was anything to damage doing that though.
« Last Edit: 03 December 2008, 08:29:41 by jimbob »
hotel21
« Reply #3 on: 03 December 2008, 08:30:02 »
Just dont overdo the lubricating!!
