Author Topic: engine turns over but wont start  (Read 3339 times)
wakedude
  • watlington,norfolk
« on: 05 December 2008, 10:15:23 »
I would like some help please,my omega has been so faithfull to me until yesterday,she turns over but wont start.
The battery is strong and ignition turns over very well but will not fire up.Any help please?
Re: engine turns over but wont start
« Reply #1 on: 05 December 2008, 10:18:59 »
Have you done a paperclip test for fault codes?
Wouldnt be suprised to see a 19 - crank sensor, in which case replace that and all will be well.
« Reply #2 on: 05 December 2008, 10:20:05 »
Do the paperclip test and post up the results :y
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
wakedude
« Reply #3 on: 05 December 2008, 10:22:53 »
ok,i will try that thanks.I will let you know the outcome.
« Reply #4 on: 05 December 2008, 10:24:16 »
As Jimbob says, you will more than likely get 19 which is the crank sensor
wakedude
« Reply #5 on: 05 December 2008, 10:42:21 »
ok,done paperclip test and only getting a 31?????
« Reply #6 on: 05 December 2008, 10:47:12 »
31 Just means engine not running, I take it it wasnt running?
wakedude
« Reply #7 on: 05 December 2008, 10:48:43 »
no wasnt running,but have tried and still no joy!! :(
« Reply #8 on: 05 December 2008, 10:53:02 »
probably is crank sensor anyway. Has it done this before? Within the last week or 2? Or just out of the blue. If this is the first instance you may find it will start when you go back to it...
On the other hand is its just happened out of the blue and refuses to start for a sustained period, i mite suspect something else.
Fuel issues maybe?
wakedude
« Reply #9 on: 05 December 2008, 11:05:03 »
i fear the worst,i suspect fuel pump.
over the last couple of months,whilst driving longish distance,a couple of occasions has happened where a momentary lack of power,like fuel blockage then back to normal,only a split second occurence but enough to set alarm bells ringing.Also a couple of times whilst idling at junction/in traffic,engine has stopped but fired up straight away.
« Reply #10 on: 05 December 2008, 11:07:39 »
I doubt its fuel pump ....particularly at idle as there is bugger all fuel need.
I suspect crank sensor as it can cause such symptoms and when totaly goosed raises a 31!
« Reply #11 on: 05 December 2008, 12:03:07 »
I'd opt for the crank sensor too! Mine gave the symptoms you describe occasionally but I got it changed before it went totally kaput :y :y
wakedude
« Reply #12 on: 05 December 2008, 12:55:21 »
thanks guys,im trying to source a new sensor,got one from EU,£35ish +vat,just need to get there to get it,bout 8 miles from me.Doh!
« Reply #13 on: 05 December 2008, 13:03:06 »
this is one occasion where genuine really is best, been no end of trouble with after market crank sensors..
« Reply #14 on: 05 December 2008, 13:37:46 »
I agree... I couldn't get a genuine one where I was at the time so fitted a Bosch one... Should be the same as they're the OE manufacturers but still getting a code 19 come up!
