Author Topic: oil cooler change or not to change?  (Read 1281 times)
VX1
  • Reading, Berkshire
« on: 10 December 2008, 14:51:49 »
That is the question..........................
Now my question is whilst I have the top half of the engine off, as I am replacing the thermostat, would it be better to replace the oil cooler as well? I have no creamy white sludge build up nothing in the expansion tank but just wondered its worth replacing yet or not? As some people say on here ' If it aint broken don't fix it'  Just wanted other opinions from other people and suggestions.
Paul  :y
Vx Trade club card holder
Halfords trade card holder
Re: oil cooler change or not to change?
« Reply #1 on: 10 December 2008, 14:54:39 »
Keep your coolant in tip top shape and it should be fine....so my reply would be no.
Also, its a lot more to remove to do it over and above the stat
VX1
« Reply #2 on: 10 December 2008, 14:58:36 »
I have the complete top off, Plenum, inlet manifold, injector rail plus the black thing the injector rail sits on. I can see the oil cooler and its easy to get too with everything off, but I can see your point though MDTM. Your reply has been noted though Mark and I thought the same as you.
Paul  :y
« Reply #3 on: 10 December 2008, 15:17:17 »
Yes but....you also need to remove:
Oil filter
Oil cooler pipes - block end - 19mm crows foot
Coolant bridge (new seals needed).
You then need
new oil cooler, cooler plate, sealent, cooler to pipes O rings
VX1
« Reply #4 on: 10 December 2008, 15:37:32 »
Oil filter
You then need
Not as straight forward as I thought then  :(
Okey dokey I will leave it then for when it does need replacing.......
Paul  :y
