Author Topic: Help Heater Not Working  (Read 2986 times)
hp7166
  • Bridgend
« on: 12 December 2008, 08:29:48 »
Hi Guys
I cant get my heater to work. I Checked the fuse and it seems ok, can anyone help its freezing!!!!
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Help Heater Not Working
« Reply #1 on: 12 December 2008, 08:31:27 »
have a fiddle with the conections on the blower, i had fualty cons with my 2.5.  :y
« Reply #2 on: 12 December 2008, 08:41:17 »
A bit more info needed.
1) Is the blower working?
2) Is the engine getting to operating temp?
3) Are the ventialtion direction controls working with the blow air moving from screen, to face, to foot well in response to the controls
hp7166
  • Bridgend
« Reply #3 on: 12 December 2008, 08:44:18 »
1) Is the blower working? No
2) Is the engine getting to operating temp? Yes
It seems to be but cant really tell as the blowers are not working
« Reply #4 on: 12 December 2008, 08:58:42 »
So the fan for the blowers is not working?
hp7166
  • Bridgend
« Reply #5 on: 12 December 2008, 09:01:41 »
Yep
« Reply #6 on: 12 December 2008, 09:07:26 »
Ok
First things to check
A) Is the scuttle empty of water (rear right of the engine bay)
B) Is fuse 33 ok?
hp7166
  • Bridgend
« Reply #7 on: 12 December 2008, 09:12:00 »
Sorry about the confusion.
I cleared the scuttle the other week but will checkl again, Fuse looked ok and did try another and it was still the same.
« Reply #8 on: 12 December 2008, 09:18:20 »
Ok, climate or standard heating setup?
When you originaly cleared the scuttle drain, was it blocked?
hp7166
  • Bridgend
« Reply #9 on: 12 December 2008, 09:22:05 »
Its Standard Heater Setup, The drain was blocked a bit with gunk no water
« Reply #10 on: 12 December 2008, 09:24:50 »
Ok, so the chances are we are looking at a fan failure.
Next stage is to remove the glove box and start measuring voltages on the fan terminals.
I assume the fan never works, not even on full speed.
hp7166
  • Bridgend
« Reply #11 on: 12 December 2008, 09:29:41 »
No The fan does not work at all, it was working yesterday but i heard like a electric zap/click when driving.
How hard is it to remove the glovebox? I guess i need to get a multi meter?
« Reply #12 on: 12 December 2008, 09:31:34 »
Check the maint guides for changing glovebox lock, that involves removing glovebox.
hp7166
  • Bridgend
« Reply #13 on: 12 December 2008, 09:45:02 »
Does anyone have a pic on the fan terminals or with they just be there when i take the box off
hp7166
  • Bridgend
« Reply #14 on: 13 December 2008, 09:48:06 »
I have removed the glove box thanks to the guide about 5 mins but cant seem to see the motor to test
here is the pic
« Last Edit: 13 December 2008, 09:48:35 by hp7166 »
Page created in 0.021 seconds with 16 queries.
