Author Topic: HELP - Locking Wheel Nuts - LOST KEY  (Read 1672 times)
wayneywoo
  • Hemel Hempstead
« on: 19 December 2008, 10:07:01 »
Guys,
I'm in a desperate situation.  I have a tyre that needs changing asap.  Went along to the garage this morning just presuming I'd find the key and I can't.  I do have the code but I'm told the keys have to be ordered in, not kept in stock.  I'm due to drive to Belguim tonight!
Can anyone help?!?!?!?!?!?
Many thanks
Re: HELP - Locking Wheel Nuts - LOST KEY
« Reply #1 on: 19 December 2008, 10:10:19 »
Most "national" tyre chains .. kwikfat etc etc seem to keep a selection of removal tools in stock, or they'll muller it off for you.. :(
« Last Edit: 19 December 2008, 10:10:40 by entwood »
waspy
« Reply #2 on: 19 December 2008, 10:13:20 »
« Reply #3 on: 19 December 2008, 10:13:54 »
If its the Vauxhall ones with the spinning ring around the outside, they're a right pain to get off.
waspy
« Reply #4 on: 19 December 2008, 10:14:45 »
My idea will be no good then :-[
« Reply #5 on: 19 December 2008, 10:21:11 »
The earlier type, with the 3 holes in the middle, have a relatively thin spinning colar and so are quite easy to cut off, the local ATS didn't even bother trying to cut them off & just used one of the above type nut removers. There is another type of nut remover though specifically intended for wheel nuts & has a finer helix.
The later 'cake cutter' Vx locking wheel nuts have a more substantial spinning collar that looks like it would be more effective.
wayneywoo
  • Hemel Hempstead
« Reply #6 on: 19 December 2008, 10:23:09 »
Thanks for the replies guys.
The key looks round with 3 holes in it.  I haven't felt it to see if any part of it spins?
Can I try whacking a socket on it and undoing it that way?
« Reply #7 on: 19 December 2008, 10:23:56 »
It took me hours of drilling and loads of drill bits to get the bloody thing off without damaging the wheel >:(
« Reply #8 on: 19 December 2008, 10:25:03 »
Same here, not a fun job, if you can, get the garage to do it, they will likely be practised and have well used techniques.
waspy
« Reply #9 on: 19 December 2008, 11:04:24 »
I personally wouldn't, you could do more harm & so make it more difficult to remove. Try a different tyre depot if you have no joy with the one you went to. These guys come accross this situation regular & so have the right tools :y :y
« Reply #10 on: 19 December 2008, 11:21:20 »
A well battered interference fit socket! ;D  ;D  :y
