Author Topic: normal running temp  (Read 1694 times)
fife_omega_v6
normal running temp
« on: 22 December 2008, 10:29:50 »
anyone know the normal running temp for 2.5 v6 on facelift
[img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00054-1.jpg[/IMG][img name=signat_img_resize]http://i404.photobucket.com/albums/pp123/fife_omega_v6/IMAGE_00059-1.jpg[/IMG]
Re: normal running temp
« Reply #1 on: 22 December 2008, 10:35:39 »
They should sit at midpoint, or just under on the guage
so 92-95ish
amba
  • Medway towns
    • German V6
« Reply #2 on: 22 December 2008, 10:53:22 »
Temp gauge should be just below mid point under normal load and only creap up when in traffic or working hard then fans will pull it back to mid point..never above 97.5.
« Reply #3 on: 22 December 2008, 15:03:47 »
mine was sitting bang on 80 degrees in the recent cold snap. And a maybe 85 degrees is more normal on mine. Thing is, as i understand it, the gauge, from what i have read is not always calibrated exactly the same from car to car. But so long ar the average is somewhere near the middle of the gauge i would not worry too much.(average taking into account winter and summer)
Kaycee
  • Doncaster
« Reply #4 on: 22 December 2008, 16:00:09 »
mine too runs at just over 85 fans kick in smack on 90 and bring it down to 85
There is a tide in the affairs of man if taken at the flood will lead on to greater things
ZEE
« Reply #5 on: 22 December 2008, 16:25:01 »
hi #
well mine is the same too starts from 80 goes to 90 then back to 85 is that normal?
« Reply #6 on: 22 December 2008, 16:37:19 »
Later cars had the temperature gauge calibrated differently. Regardless of the numbers, just below the  middle of the gauge is typical, rising to just above the middle of the gauge in traffic or arduous conditions, whereby the fans should bring the temperature under control.
fife_omega_v6
« Reply #7 on: 22 December 2008, 17:09:48 »
thanks for that folks
« Reply #8 on: 22 December 2008, 19:31:31 »
Both our 2.5 V6s run at 95ºC - up to 98ºC in traffic when fans kick in & bring back down to 95ºC.
Cold weather running around 92ºC
Hope that helps.
« Reply #9 on: 23 December 2008, 07:57:15 »
iirc Facelifts and prefacelifts have different temperatures written on the guage......
However, the needle should be just below midpoint on both.
hotel21
  • The Kingdom of Fife
« Reply #10 on: 23 December 2008, 08:40:53 »
Yup.  Facelift shows as 80 and the prefacelift shows as 90.  Midpoint or below for the needle, rising in traffic sometimes, drawn back down by the fans kicking in.
