Author Topic: Brake wear indicator  (Read 2488 times)
NickA
  • Cambridge
« on: 23 December 2008, 19:05:09 »
How much meat is left on the front pads once the check control comes on? In other words am I OK for a couple of hundred miles over Xmas or should I nip out to the local stealers tomorrow morning? I need discs as well so I'll rather wait until after Xmas.
Also anyone fitted disc from Autovax, or is it really worth the extra for genuine parts?
Re: Brake wear indicator
« Reply #1 on: 23 December 2008, 19:08:22 »
Err? Have a look! ;) It really depends on how much of an unworn lip there is on your discs. The bigger the lip, the earlier the warning light/message will appear. I had mine on for months before I did anything about it - my discs are nearing the end of their life too.  :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 23 December 2008, 19:11:25 »
You should be ok for a couple hundred miles mate, think you can get a kit, discs and pads from Vauxhall for about £100, less with a Trade Club Card  :y
Also check that the sensor hasn't just come off  :)
« Last Edit: 23 December 2008, 19:12:04 by Loo-knee »
« Reply #3 on: 23 December 2008, 20:30:41 »
....... Also check that the sensor hasn't just come off  :)
That wouldn't trigger a fault. It's when the sensor goes open circuit that triggers it. ;)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #4 on: 23 December 2008, 20:32:27 »
Why did mine do it then?
« Reply #5 on: 23 December 2008, 20:36:30 »
Must have broke as it came off the pad. Try it. Unplug the sensor from inside the wheel arch, & it'll put the light/message on. Short out the terminals in the plug & it'll get shut of the message. I've done it afew times over the years with this Omega & the Senators before it, when a sensor has worn through early. If you have a new sensor plugged into the car & just tuck it up out the way, the car will be happy & not show a light/message.
« Last Edit: 23 December 2008, 20:38:36 by Andy_B »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #6 on: 23 December 2008, 20:39:18 »
Right follow you now, mine was broken  :-X
Was the open circuit posh talk  ::)
Ok I should have said broken not come off :-*
« Reply #7 on: 23 December 2008, 20:42:48 »
;) = when the two wires inside are NOT connected.  :y  :y
 ;D  ;D
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #8 on: 23 December 2008, 20:46:50 »
Ok I hold my hand up I was wrong  :'(
Sorry Andy  ::)
it must be Christmas, I am apologising  :P
« Reply #9 on: 23 December 2008, 20:49:16 »
Sorry Andy  ::)
 ;D  ;D  ;D  ;D  ;D
NickA
  • Cambridge
« Reply #10 on: 26 December 2008, 16:14:37 »
Just replaced the discs and pads. Pads were OK with 4mm left but discs had a large lip which had triggered the sensor. I used genuine Vaux parts as the local dealer was prepared to give me trade prices.
I've only got a wear sensor on the near side; I assume that's a facelift cost saving?
« Last Edit: 26 December 2008, 16:15:15 by NickA »
« Reply #11 on: 26 December 2008, 17:27:14 »
You assume correctly :) :) :)
« Reply #12 on: 27 December 2008, 10:20:19 »
Get yourself a Trade Club card - the savings on standard service type items are worthwhile (cheaper than trade price)
« Reply #13 on: 27 December 2008, 10:22:48 »
I tend to change mine around the time the warning comes on - the last bit of the pad seems to 'go off' a bit to quickly with all the roundabouts in Milton Keynes.
Had to change the pads on the tractor a few weeks ago, and they'd only done around 3k - cooked them pretty bad, couldn't get the bit to return :(
NickA
  • Cambridge
« Reply #14 on: 27 December 2008, 17:36:43 »
IHad to change the pads on the tractor a few weeks ago, and they'd only done around 3k - cooked them pretty bad, couldn't get the bit to return :(
3K  :-? I get 60K out of the fronts and the rears are the originals at 127K
